Small pressure gradient causes large velocity |
Greetings,
I am using simpleFoam running a simple case. The geometry is a simple box with 4.5*4.5*1 [mm], with mesh setup of 45*45*10. The inlet boundary condition: p = 6011; v = zeroGradient; The outlet boundary condition: p = 6010; v = zeroGradient; Internal field p = 6010; v = 0.1; walls = no-slip the pressure gradient of the entire flow field is small, which is 1. however the final result of velocity reaches ~18 m/s maximum. Such small pressure gradient should not create such large velocity. I ran the exactly same case in fluent to check this, and it gave me a reasonable 1.4 m/s, which is expected. so what's the problem with my openFoam case? attached is y-normal cutting-surface |
Yuncheng Xu (Cloud)
Rep Power: 15 ![]() |
According to your setup, where U is zero-gradient inlet and outlet, based on force balance, the flow field won’t converge until the pressure gradient equals to the shear force which induced by the non-slip wall. So the velocity here depends on near wall mesh size, residual accuracy and wall functions if use turbulence model.
By the way, this BC setup does not make any physical sense in a steady condition. |
#3 | |
pressure and velocity, pressure gradient |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Pressure Gradient and Velocity Divergence | alvin11 | Main CFD Forum | 4 | May 29, 2010 11:11 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
