alphaEff() myXiFoam
Old   February 15, 2018, 08:35
Post alphaEff() myXiFoam
kaizhangqmul is on a distinguished road
Dear Friends,
I am trying to implement the new algebraic combustion for XI as that given in ehsanYasariReport.pdf. I remember this worked fine many years ago when i used old version of openfoam.
But now, in 5.x, it gives out a mistake casued by
tauTurbPrime = (turbulence->alphaEff()-thermo.alpha())/(rho*pow(up,2));
where i found turbulence->alphaEff() = thermo.alpha() = 1e-05......and then tauTurbPrime = 0.
and In,
S_turbTimeDependent=S_turb*
sqrt(1.+tauTurbPrime/(runTime+tO)*(exp(-1.*(runTime+tO)/tauTurbPrime)-1.));
Division by 0 appeared.
Shouldn't we have turbulence->alphaEff() = turbulent thermal diffusivity + molecular thermal diffusivity and subtract it from thermo.alpha (molecular) gives turbulent thermal diffusivity? but this will always lead to a 0 turbulent thermal diffusivity at time 0 and for this implementation we cant continue.
Can anyone help please?
Best,
Kai.
kaizhangqmul is offline   Reply With Quote
Old   February 15, 2018, 13:07
feel like i have solved it, but still got some problems that b value could drop below 0 and give error in half way. This error also occur for algebraic Xi model with negative b.
alphaeff()
alphaEff zahraa OpenFOAM Pre-Processing 5 May 17, 2020 09:43
Fixed heat flux BC in buoyantPimpleFoam bhh OpenFOAM Running, Solving & CFD 39 January 12, 2019 09:51
Heat flux calculating with wallHeatFlux utility and alphaEff tanshihaj OpenFOAM Post-Processing 0 March 12, 2014 06:55
Accessing fields and dictionaries from within a BC implementation alberto OpenFOAM Running, Solving & CFD 12 December 6, 2011 10:30
alphaEff scalarField deji OpenFOAM 1 July 29, 2010 15:12
