surface to surface radiation
Old   February 14, 2018, 14:55
Default surface to surface radiation
srikanthallu is on a distinguished road
I am trying to setup a simple multiple region heat transfer solver with radiation.
In the domain, I have two solid regions separated with a fluid region setup with P1 radiation model. When the fluid region has low absorptivity/emissivity and one solid domain is maintained at constant high temperature, the predominant transfer of heat should occur to the second region through radiation.
My question is does the P1 radiation model account for surface-surface radiation with radiative flux converted to heat source for thermal transport in solid region.
I appreciate any suggestions/pointing to documentation and examples.
Thanks
srikanthallu is offline   Reply With Quote
p1 model, radiation exchange
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 06:41
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
radiation flux rejected from surface sachin kumar Main CFD Forum 1 June 16, 2015 03:43
Modeling the flow of solar radiation as the heat flux from the surface. Gebbels FLUENT 0 March 25, 2012 15:39
radiation from road surface star Main CFD Forum 0 January 12, 2009 00:13
