ImportError: No module named PyFoam.RunDictionary.ParsedParameterFile
Old   February 13, 2018, 04:23
Default ImportError: No module named PyFoam.RunDictionary.ParsedParameterFile
Hans Kurst
jimswa is on a distinguished road
Hello!
In my OpenFoam case I launched a Python file. In the beginning of the script I want to import the ParsedParameterFile by the command:
from PyFoam.RunDictionary.ParsedParameterFile import ParsedParameterFile
But I always get the error:
I would be grateful if you could help me!
jimswa is offline   Reply With Quote
Old   November 27, 2018, 12:40
Marius Bünker
Blumenkind is on a distinguished road
I had the same problem. Switching the Python Intepreter to my version of Python 2 solved it for me. Can anybody confirm?
On the PyFoam-Wikipage it is written, that Python 3 is generally supported, but only Python 3.4 is tested. Is my version of Python 3 (3.6.7) the problem?
Edit: OK, seems like I just need to set the path for Python3 and try again. Will do tomorrow...
Edit2: PyFoam is installed in the Python 2.7-Folder. If I want to run it with Python3, the path has to be set with the following lines. (It may cause problems, if you have the same dist-packages in python2.7 as in python3)
import sys
sys.path.append('/usr/local/lib/python2.7/dist-packages'
Blumenkind is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
