Problem with roughnesstoFoam/ version problem |
February 6, 2018, 12:18 |
Hans Kurst
Rep Power: 8 |
I have a problem with an already exisiting case which is discribed here: http://openfoamwiki.net/index.php/Co...oughnessToFoam The code is hosted on Github: https://github.com/hananel/roughnessToFoam I tried to launch the case, but it doesn't work. I found in other threads that this data was created in OpenFoam 4 and I have the version 5.0.1 . Do you maybe know what I need to modify so that it works. Il also tried the commands: blockMesh snappyHexMesh -overwrite But then the following error message occurs: --> FOAM FATAL ERROR: Number of cells in mesh:8000 does not equal size of cellLevel:24880 This might be because of a restart with inconsistent cellLevel. From function Foam::scalar Foam::hexRef8::getLevel0EdgeLength() const in file polyTopoChange/polyTopoChange/hexRef8/hexRef8.C at line 355. . . . Thank you for your help! |
February 6, 2018, 21:36 |
Rep Power: 16 |
Based on your error message, it would seem like that you would need to clean your case before beginning the meshing process again. Have you given that a try? Delete the points/faces/cellZones/boundary files in polyMesh folder and try running from blockMesh again. At the very least the error message that you are seeing right now, should go off. Cheers, Antimony |
February 7, 2018, 10:21 |
Hans Kurst
Rep Power: 8 |
Thank you for the answer, but I already tried it.
I changed the commands to: blockMesh decomposePar snappyHexMesh Now, the mesh is created. But how does it work to take the roughnesstoFoam into account? |
Problem in compiling a solver made for a different version (v2.0 ->v4.1) | JLS | OpenFOAM Programming & Development | 2 | July 9, 2019 15:03 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 08:11 |
OpenFOAM-1.6 install cookbook | MadsR | OpenFOAM Installation | 372 | November 20, 2010 12:57 |
version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found | ovie | Main CFD Forum | 1 | April 19, 2010 15:00 |
Fluent New Version 6.3 Problem Help!!!! | phinix | FLUENT | 1 | March 15, 2007 21:16 |
