December 19, 2017, 16:35 |
Simulation exit without error
Sebastian Vetter
Rep Power: 9 |
I'm quite new to OpenFoam and having some problems with my case. I am using the solver pimpleCentralFoam and set everything up so far. But the Problem is that the simulations stops without any error message and I don't know why. I hope you can help me and thanks in advance! Whats in my terminal: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : pimpleCentralFoam Date : Dec 19 2017 Time : 20:31:14 Host : "ThinkPad13" PID : 229 Case : /mnt/c/Projektarbeit/BasedOnBackwardStep_1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Creating field kinetic energy K Selecting finite volume kappaFunction type standardMachToAcCourantRatio Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kOmega kOmegaCoeffs { betaStar 0.09; beta 0.072; gamma 0.52; alphaK 0.5; alphaOmega 0.5; } No finite volume options present No MRF models present Marking cells with bad quality to limit pressure gradient max/min FaceAcCourant: 0.0721447/2.28841e-05 max/min Maf: 0/0 max/min kappa: 0/0 Courant Number max : 0 velocity magnitude: 0 Starting time loop Mean and max Characteristic Courant Numbers = 0.000733386 0.0721447 Courant Number max : 0 velocity magnitude: 0 deltaT = 0.001 Time = 0.001 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 rho max/min : 4.09775 / 0.819549 PIMPLE: iteration 1 DILUPBiCGStab: Solving for omega, Initial residual = 0.334139, Final residual = 5.6778e-16, No Iterations 111 DILUPBiCGStab: Solving for k, Initial residual = 1, Final residual = 9.11384e-16, No Iterations 31 bounding k, min: -0.363994 max: 0.213129 average: 0.000267676 DILUPBiCGStab: Solving for h, Initial residual = 0.651609, Final residual = 6.78465e-16, No Iterations 21 max/min T: 425/425 DILUPBiCGStab: Solving for p, Initial residual = 0.000486029, Final residual = 6.1208e-16, No Iterations 301 max(U): (297.448 1.39344e-12 523.822) max/min p: 500000/100000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 rho max/min : 4.09767 / 0.819711 time step continuity errors : sum local = 2.14872e-09, global = -5.95084e-12, cumulative = 0 max/min FaceAcCourant: 62001/65.7294 max/min Maf: 1.52823/0 max/min kappa: 0.00481344/0 PIMPLE: iteration 2 DILUPBiCGStab: Solving for omega, Initial residual = 0.666186, Final residual = 1.91444e-17, No Iterations 3 bounding omega, min: -1.71684 max: 2.2804e+08 average: 430618 DILUPBiCGStab: Solving for k, Initial residual = 0.993415, Final residual = 5.20457e-16, No Iterations 33 DILUPBiCGStab: Solving for h, Initial residual = 0.814062, Final residual = 28.3773, No Iterations 1001 max/min T: 3.58195e+07/-7.03686e+07 |
December 20, 2017, 01:18 |
Uwe Pilz
Rep Power: 15 |
The number of iteration just at the start is much to high. The system in in an instable state. As ypu can see, T raises to very high values. I recommend first reducing delta t to a much smaller value. It doesn't count to start wit for instance 1e-7 i you use automatic time step control.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
December 20, 2017, 10:52 |
Sebastian Vetter
Rep Power: 9 |
thanks for your answer. I already had very small time steps and the only difference was that the Courant number was very small (e-20). But the overal "result" was the same and the Simulation stopped too. |
December 20, 2017, 13:14 |
Uwe Pilz
Rep Power: 15 |
That doesn't seem to be true:
December 22, 2017, 04:45 |
Sebastian Vetter
Rep Power: 9 |
Hallo, wir können das ganze ja wahrscheinlich auch auf Deutsch machen.
Ich meinte, dass ich bereits vorher einige Versuche mit kleineren Zeitschritten gemacht habe. Bei der, die ich hier hinein gestellt habe, bin ich etwas größer geworden, da die Courant Zahl extrem klein war, allerdings waren die Ergebnisse in beiden Simulationen gleich. |
openfoam, pimplecentralfoam; |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 01:10 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 10:40 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 21:16 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 06:07 |
