November 16, 2017, 10:42 |
XiFoam ignition dimension
Huy Quang Dong
Rep Power: 9 |
Hello everyone!
I'm trying to study the XiFoam solver. I've satrted with this tutorial : XiFoam/RAS/moriyoshiHomogeneous based on this case i create a large scale fire scenario (always 2D) : xmax= 80 m (800 cells) and ymax (height)= 40 m (400 cells). my mesh size is : 10 cm x 10 cm. Do you think it's too coarse for the solver? when i try to run it, the fuel is not ignited. Here is my igntion block : ignitionSites ( { location (0 0 0.05); diameter 0.2; start 0; duration 0.005; strength 2; } ); ignitionSphereFraction 1; ignitionThickness ignitionThickness [0 1 0 0 0 0 0] 0.001; ignitionCircleFraction 0.5; ignitionKernelArea ignitionKernelArea [0 2 0 0 0 0 0] 0.001; I don't know how to chose the right ignition parameters and what is the meaning of : + ignitionThickness + ignitionKernelArea Thanks in advance! |
Ignition and flame propagation with XiFoam for a few meters long comput. domains | Gloq | OpenFOAM Running, Solving & CFD | 1 | February 21, 2023 13:22 |
Several ignition sites with XiFoam? | lfgmarc | OpenFOAM Running, Solving & CFD | 4 | May 2, 2018 03:09 |
[ANSYS Meshing] Refinement dimension is not working | Tasos | ANSYS Meshing & Geometry | 0 | May 13, 2017 10:07 |
XiFoam lean-premixed combustion instabilities | remir | OpenFOAM Running, Solving & CFD | 8 | April 15, 2016 09:31 |
Ignition modeling | Julie Polyakh | Siemens | 0 | May 20, 2004 09:05 |
