Huge increase of RAM makes parallel mpirun fails |
November 8, 2017, 10:34 |
Charlie Barraud
Rep Power: 10 |
I am trying to launch a 2D simulation in my University cluster which runs on SLURM workload manager. My case is quite simple, the mesh being regular and homogeneous. I tested it on my local machine and there is no problem but when running in the cluster, the RAM hugely increases leading to the fail of the work "slurmstepd: error: Exceeded job memory limit at some point." The available memory is 45 GB. In my local machine only 2 GB are used anyway. Now the weird thing is that I was so desperate so I tried to run a 2,500,000 cells case which was successful. This randomness is a bit disorientating. Could it come from the MPI settings of the cluster ? Any one had the same issue ? I thank you all for your time and hope you can provide me with some help, Charlie |
November 11, 2018, 17:38 |
M. Montero
Rep Power: 17 |
Here the same problem. Did you find how to solve it?
November 12, 2018, 11:42 |
Edward
Rep Power: 8 |
If your case file runs perfectly on your local machine, then there must be an issue with either your SLURM script file or the MPI settings on the cluster.
I would first double check my script files to make sure my code is correct and then try asking your University cluster administrator for help. |
cluster computing, mpi error, parallel calculation, ram issues |
[snappyHexMesh] Error while running SnappyHex in parallel | mg.mithun | OpenFOAM Meshing & Mesh Conversion | 1 | February 10, 2016 14:13 |
MPIRUN fails | lfbarcelo | OpenFOAM | 3 | March 29, 2010 08:41 |
1.6.x -> snappyHexMesh in parallel fails ... | podallaire | OpenFOAM Bugs | 11 | August 4, 2009 14:57 |
Does it metter to increase RAM for solver speed?? | raima | Main CFD Forum | 1 | February 28, 2008 11:47 |
Serial run OK parallel one fails | r2d2 | OpenFOAM Running, Solving & CFD | 2 | November 16, 2005 13:44 |
