Open Foam for particle lifting with gas dynamics |
October 16, 2017, 19:37 |
Hello, I am new to OpenFoam and trying to determine what would be a better code to simulate my problem, OpenFoam or FLASH. Basically, I want to simulate the particle lifting due to spark-induced time-varying shock (cylindrical/spherical) and the interaction of the shock with plasma (produced from spark discharge). Any suggestions/comments regarding what modules to use in OpenFoam will be much appreciated. Thanks!
eulerian-lagrangian, gas-particle, gas-particle module, plasma-particle, spark induced shock |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
