How to get volume averaged quantity of a simulation |
October 11, 2017, 00:24 |
Rep Power: 11 |
I have a simulation running in OpenFoam. I have a region (cellZone) that I want to track the temperature in over time of the simulation (transient simulation).
How do extract the volume temperature from this region to view the data (preferably not via ParaView but that is also an option). Is this something I can do with the postProcess tool? |
October 11, 2017, 05:40 |
Brian Willis
Rep Power: 15 |
Have a look at the options available which act on the field as a runtime available post process function. You can either volume integrate or most likely volume average.
http://www.openfoam.com/documentatio...eld-value.html |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Loosing Volume, High Simulation Time and Problem About stl File | thetitans | FLOW-3D | 3 | December 1, 2016 07:36 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
Stuck in a Rut- interDyMFoam! | xoitx | OpenFOAM Running, Solving & CFD | 14 | March 25, 2016 08:09 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
