Multiple patch types for different mesh regions
Old   October 10, 2017, 06:34
Post Multiple patch types for different mesh regions
Marc
Dreoasteh is on a distinguished road
I'm working on a conjugate heat transfer multi-region case, the mesh can be seen in the first attachment.
After snappyHexMesh, the mesh is divided into a solid and a fluid region (seen in the next two attachments).
The walls (i.e. all boundaries excluding inlet and outlet) in blockMesh from which the mesh is built from are set as symmetryPlane.
My aim is to have the fluid walls as "symmetryPlane" but the solid walls as "wall" because I want to set a fix temperature to them.
I tried editing constant/solid/polyMesh/boundary and manually changing the entries "type" and "inGroups" of the desired patches from "symmetryPlane" to "wall" but during a decomposePar command I got this error:
--> FOAM FATAL ERROR:
Attempt to cast type wall to type symmetryPlane
    From function To& Foam::refCast(From&) [with To = const Foam::symmetryPlaneFvPatch; From = const Foam::fvPatch]
    in file /scratch/marrs/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/typeInfo.H at line 114.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::symmetryPlaneFvPatch const& Foam::refCast<Foam::symmetryPlaneFvPatch const, Foam::fvPatch const>(Foam::fvPatch const&) at ??:?
#3  Foam::symmetryPlaneFvPatchField<double>::symmetryPlaneFvPatchField(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#4  Foam::fvPatchField<double>::adddictionaryConstructorToTable<Foam::symmetryPlaneFvPatchField<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#5  Foam::fvPatchField<double>::New(Foam::fvPatch const&, Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/scratch/marrs/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/decomposePar"
#6  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::dictionary const&) in "/scratch/marrs/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/decomposePar"
#7  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) in "/scratch/marrs/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/decomposePar"
#8  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::readFields() in "/scratch/marrs/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/decomposePar"
#9  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/scratch/marrs/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/decomposePar"
#10  ? in "/scratch/marrs/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/decomposePar"
#11  ? in "/scratch/marrs/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/decomposePar"
#12  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13  ? in "/scratch/marrs/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/decomposePar"
If anyone can point me in the right direction for changing patch types in different regions (in case this can actually be done, which I'm not sure of) I'd be very grateful.
Edit: I just tried a normal (i.e. non-parallel) chtMultiRegionSimpleFoam run and it worked. However, I do need to run my cases in parallel, so how could I solve the decomposePar error?
Dreoasteh is offline   Reply With Quote
chtmultiregionsimpefoam, multi region, patch type, symmetry
Problem with cyclic boundaries in Openfoam 1.5 fs82 OpenFOAM 37 November 29, 2024 11:15
Boundary conditions for dynamic mesh interface patch between two mesh regions Virag OpenFOAM Running, Solving & CFD 8 May 31, 2016 19:33
[Commercial meshers] Problems with ANSYS mesh conversion tdog OpenFOAM Meshing & Mesh Conversion 1 March 31, 2016 18:36
Cyclic Boundary Condition Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Running, Solving & CFD 36 July 2, 2012 13:23
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
