about using openfoam in Linux (new user)
Old   October 2, 2017, 16:10
Default about using openfoam in Linux (new user)
Zoheb Nasir
shoumo_30 is on a distinguished road
Hello every one.
I have a question regarding OpenFOAM. Previously I used StarCCM for my modeling, but now I have to use opensource software and as a result OpenFOAM is my only choice. Most of my simulations will be based on wind around structures/buildings.
For modelling, I will be able to use google sketch up and I am planning to use gmsh for my meshing and then convert the mesh to use in openfoam. I am not sure my idea is good or bad.
Another thing I need to use Linux based operating system (not sure which one will it be?).
Can anyone help me with this. Is it a good idea to use gmsh to do the meshing and then take it to openfoam and run. I heard after meshing I can use snappyhexmesh to do wind around building simulations.
Thanks in advance for your assistance.
Zoheb
shoumo_30 is offline   Reply With Quote
Old   October 3, 2017, 06:25
Teosim is on a distinguished road
as a new user myself back in time I had no problem in setting up OpenFOAM in both Ubuntu and Debian. I think the choice of the distribution is a matter of tastes.
For geometry creation and manipulation I often use Salome and Blender and then meshing is done with SnappyHexMesh. This is the work-flow I adopt even when dealing with wind around structure but there might be other efficient (or even better) ways, involving sketch-up, gmsh and/or others.
Teosim is offline   Reply With Quote
Old   October 3, 2017, 09:51
Zoheb Nasir
Thank you very much Teosim. Actually, I have been suggested to use google sketch up. That is why I was thinking of using sketch up. However, I heard in sketch up's new version snappy hex mesh can be done right a way. However, I am not sure about it.
Zoheb
new user, openfoam
[Docker] Running OpenFoam 4.1 from script without user intervention fnellmeldin OpenFOAM Running, Solving & CFD 9 June 7, 2017 19:04
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
OpenFOAM 1.7 installation on Redhat linux maxims OpenFOAM Installation 2 November 30, 2012 05:29
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 16:39
