September 18, 2017, 06:12 |
the error in LRR model (channel flow)
Kazuki ODA
Rep Power: 9 |
It's my first post on this forum. I'm openfoam beginner. I want to use Reynolds Stress Model (LRR model) in channel flow by using simpleFoam. But, I get the error. Please give me advice the error. First, I use k-ε model in channel flow.The model performs ok. So, "relaxation Factors" change all 0.5. add Fieldfile (0/R) and change LRR from k-ε. The result is such as error contents. I can't understand the cause of error. -----------------error contents------------------------------------ Time = 0.0001 Courant Number mean: 0 max: 0 velocity magnitude: 0 DILUPBiCG: Solving for Ux, Initial residual = 0.999331, Final residual = 0.000100888, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.999331, Final residual = 0.000100888, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00620118, No Iterations 16 time step continuity errors : sum local = 1.38496e-10, global = -1.68073e-25, cumulative = -1.68073e-25 DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.000148364, No Iterations 1 DILUPBiCG: Solving for Rxx, Initial residual = 1, Final residual = 5.38634e-05, No Iterations 1 DILUPBiCG: Solving for Rxy, Initial residual = 1, Final residual = 5.38707e-05, No Iterations 1 DILUPBiCG: Solving for Ryy, Initial residual = 1, Final residual = 5.38678e-05, No Iterations 1 DILUPBiCG: Solving for Rzz, Initial residual = 1, Final residual = 5.38636e-05, No Iterations 1 ExecutionTime = 0.1 s ClockTime = 0 s Time = 0.0002 Courant Number mean: 1.24654e-08 max: 1.97961e-06 velocity magnitude: 6.21442e-06 Segmentation fault (Core dump) --------------------------------------------------------------------------- --------------------------------------0/R--------------------------------- Code:
FoamFile { version 2.0; format ascii; class volSymmTensorField; location "0"; object R; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * / dimensions [0 2 -2 0 0 0 0]; internalField uniform (0 0 0 0 0 0); boundaryField { bottomWall { type zeroGradient; } topWall { type zeroGradient; } sides1 { type empty; } sides2 { type empty; } inout1 { type cyclic; } inout2 { type cyclic; } } Your help is highly appreciated. Thanks! oda |
September 18, 2017, 09:19 |
Timofey Mukha
Rep Power: 14 |
This probably wont fix the error, but shouldn't you set fixedValue 0 as bc on the walls for the Re-stresses?
Sent from my iPhone using CFD Online Forum mobile app |
September 18, 2017, 21:31 |
Kazuki ODA
Rep Power: 9 |
Hi tiam!
Thank you for your advice. I tried that method. But, the same result has come out. I think that BC is wrong because one step can be calculated. Is that correct? Thanks! oda |
September 19, 2017, 01:28 |
Kazuki ODA
Rep Power: 9 |
Hi tiam!
Please forgive my continuous post. I created a graph of residuals in my calculated channel flow and attached that graph. But, this graph looks like vibration. Is this affecting LRR? Now, relaxationFactors is as follows. p 0.3; U 0.7; k 0.7; epsilon 0.7; R 0.7; nuTilda 0.7; How should I change it? Please help me. oda |
September 19, 2017, 03:07 |
Timofey Mukha
Rep Power: 14 |
Sorry, I dont think I can, I have no experience with such models or how they should behave. Regarding the bc at the walls, zero Re-stresses simply follow from the fact that you have no-slip for the velocity.
September 19, 2017, 04:57 |
Kazuki ODA
Rep Power: 9 |
Hi tiam!
I appreciate your advice.Thank you very much. Please tell me if you understand something. Thank oda |
September 21, 2017, 02:21 |
method to run LRR
CFDfreak
Rep Power: 9 |
hello
Recently I have run a problem using LRR. There is a separate thread in this forum how to run LRR/SCG. please read that forum. I was using openfoam 4.1. Instead of giving R as a initial condition try to generate R using utility file. It can be found within your openfoam folder. Then run the file using laminar/any other turbulent model. After running for certain timestep change the model to run LRR. Also reduce all the under relaxation to 0.1 to 0.2. If it is compressible flow keep density relaxation as 0.01-0.05. Last edited by nandhakumar; September 25, 2017 at 05:04. |
lrr simplefoam channel, rsm |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Simulating a Laminar Isothermal Flow in a 2D rectangular Channel | HectorRedal | Main CFD Forum | 1 | December 18, 2016 11:41 |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 11:44 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 16:28 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
