Sedfoam for OpenFoam 5.0
Like Tree10Likes
Old   April 19, 2020, 12:12
cyss38's Avatar
Cyrille Bonamy
cyss38 is on a distinguished road
Do you have the sedFoam_rbgh executable?
If you have it, all the tutorials should work and you can start to work.
Regarding the problem of the "MULES" version, I would need more info on the error; Can you provide me with the entire error file?
cyss38 is offline   Reply With Quote
Old   April 19, 2020, 14:51
mohammed tareq
mohammedtareq is on a distinguished road
No i dont have sedFoam_rbgh executable
how can i sen the file to you?
thanks for replay
mohammedtareq is offline   Reply With Quote
Old   May 19, 2020, 22:44
abdikerim kurbanaliev
kerim is on a distinguished road
Hi there,
Is sedFoam 3.0 compatible with OpenFOAM7? I am using OpenFOAM 7 on installed ubuntu 16.04.6 LTS.
Thanks in advance.
Kerim
kerim is offline   Reply With Quote
Old   May 20, 2020, 04:51
Cool
  #24
cyss38's Avatar
Cyrille Bonamy
Originally Posted by kerim View Post
Hi there,
Thanks in advance.
Kerim
Hi Kerim,
No problem to use OpenFOAM7 with the last version of sedfoam. Just use the github link to download sedfoam :
git clone https://github.com/sedfoam/sedfoam
Old   May 20, 2020, 07:51
Originally Posted by cyss38 View Post
Hi Kerim,
Dear Cyrille,
I have downloaded sedFoam and installed it by using ./Allwmake command in the terminal.
When I tried to run 1DBedLoad tutorial I got next error:
kerim@kerim-Lenovo-ideapad-320-15IKB:~/run/1DBedLoad$ ln: ./lnInclude
/home/kerim/run/1DBedLoad/0/alpha_a.#codeStream: In function ‘void Foam::codeStream_3e1ed2685b83ff49904701f3471ce9f74 9f5e204(Foam::Ostream&, const Foam::dictionary&)’:
/home/kerim/run/1DBedLoad/0/alpha_a.#codeStream:56:17: error: ‘Foam::scalarField {aka class Foam::Field<double>}’ has no member named ‘writeEntry’
make: *** [Make/linux64GccDPInt32Opt/codeStreamTemplate.o] Error 1
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_3e1ed2685b83ff49904701f3471ce9f749f5e204/platforms/linux64GccDPInt32Opt/lib/libcodeStream_3e1ed2685b83ff49904701f3471ce9f749f5 e204.so"
file: /home/kerim/run/1DBedLoad/0/alpha_a from line 18 to line 18.
From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
in file db/dictionary/functionEntries/codeStream/codeStream.C at line 218.
FOAM exiting
What does it mean?
I have attached two pictures and text file of sdeFoam compilation for more information.
Kerim
Old   December 1, 2020, 19:52
Default Same Problem
  #26
Vahid
va-ta-cfd is on a distinguished road
Dear Cyrille,
FOAM exiting
What does it mean?
Kerim
Hi Kerim,
I face the same problem.
Did you have any progress on this issue?
Thanks if anyone could help.
va-ta-cfd is offline   Reply With Quote
Old   April 29, 2021, 09:18
Default error while installing sedfoam
  #27
Sourav Hossain
sourav8016 is on a distinguished road
Dear Sir,
I have been trying to install sedfoam. I am using openfoam6 in ubuntu 16.04. While running ./Allwmake command, I get the following errors
Foam::sedIncompressibleTurbulenceModel<TransportMo del>:Primef() const’:
../TurbulenceModels/turbulenceModels/lnInclude/sedIncompressibleTurbulenceModel.C:128:12: error: ‘New’ is not a member of ‘Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >’
return tmp<surfaceScalarField>::New
/home/sourav/OpenFOAM/OpenFOAM-6/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt64Opt/sedFoam_MULES.o' failed
make: *** [Make/linux64GccDPInt64Opt/sedFoam_MULES.o] Error 1
Please help me out. Thanks in advance.
sourav8016 is offline   Reply With Quote
Old   December 8, 2021, 05:58
Smile In which version of OpenFOAM sedFoam is well established?
  #28
Thokala Divya
divyathokala01@gmail.com is on a distinguished road
Hi there,
I am would like to use sedFoam for my research. I am totally confused with .org, .com and version which it supports well. Can someone help me out in choosing which version can I try weather ESI of foundation and the version number
divyathokala01@gmail.com is offline   Reply With Quote
Old   December 8, 2021, 06:02
cyss38's Avatar
Cyrille Bonamy
Regarding sedfoam we only support openfoam.com
And i suggest you download the develop branch
bed load, open foam 5, sedfoam, sediment transport model
boundary conditions in fvMatrix multiplication make me despair marek88 OpenFOAM 5 August 25, 2018 04:55
OpenFOAM 5.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 11 June 6, 2018 00:48
Make/options problem while porting model to OF 5.0 klausb OpenFOAM Programming & Development 1 August 9, 2017 17:59
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface James Date CFX 3 August 10, 2012 05:47
Free seminar: ICEM CFD version 5.0 Gavin Butcher CFX 0 June 17, 2004 11:49
