Rep Power: 0 ![]() |
Hello!
I am trying to make a kind of von Karman channel with an airfoil in a cylinder. The main problem is that even though there is no problem doing pimpleFoam, when I go to paraView the velocity field is constant (photo). I think it may be a boundary problem, but it seems to be ok. Does anybody know how to fix it |
Hello anbalra,
do you have any log files from the pimpleFoam run? This just looks like you have displayed your initial condition. Also, it would be helpfull to have a case that can be actually ran (if it is not too big). Best wishes, Martin |
Hello!
Yes, here you are https://drive.google.com/open?id=0Bz...WNxWDBTS2ZRVTA I tried to do the same experiment with a different mesh, but it doesnt work neither.. but looks better (airfoilkarman2) |
No vortex shedding for flow over cylinder at Re = 59 using pimpleFoam | kaszt | OpenFOAM Running, Solving & CFD | 9 | March 15, 2022 07:34 |
What's happening to my solution for lower relaxation factor | casesam | OpenFOAM Running, Solving & CFD | 3 | October 22, 2015 01:25 |
Analytic solution for 2D steady Euler equations | jojo81 | Main CFD Forum | 0 | October 15, 2012 12:05 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
