fvc::ddt(alphac) equals zero
Old   August 3, 2017, 04:10
Default fvc::ddt(alphac) equals zero
Dongyue Li
sharonyue is on a distinguished road
Hello guys,
Below is the pressure equation In MPPICInterFoam:
fvScalarMatrix p_rghEqn
            fvm::laplacian(Dp, p_rgh)
            fvc::ddt(alphac) + fvc::div(alphacf*phiHbyA)
//Info << fvc::ddt(alphac);
The problem is that fvc::ddt(alphac) is zero all the time. After commenting out this term, the solver gives the same result.
Below is from Jasak:
HTML Code:
Thus, if you try to evaluate the ddt the way it is written, it will recognise that the field does not have the oldTime() level stored and will use the current value to initialise it. Basically, fvc::ddt(magSqr(U)) will always give you zero, which is wrong.
One reason is that the alphac is so small, but it should not be zero. I am not sure ifs a bug.
My OpenFOAM algorithm website: http://dyfluid.com
By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam
We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html
sharonyue is offline   Reply With Quote
Old   July 19, 2019, 08:21
Rahul Subburaj
RahulSubbu is on a distinguished road
Dear Sharonyue,
I am also trying to use the MPPICinterFoam. I have a few queries:
1. In the lines of UEqn.H, there is no alphaRhoPhic term. How did they include this term?
2. rhoPhi in alphaEqn.H seems to be similar to alphaRhoPhic.
Thanks in advance.
RahulSubbu is offline   Reply With Quote
Old   June 21, 2021, 11:16
Armin Alavi
ArminAlavi is on a distinguished road
Hello Dongyue
I am facing the very same problem you had, and I wonder if you have managed to solve it. I am using OpenFoam6 by the way. I would really appreciate it if you could share your idea on this problem.
ArminAlavi is offline   Reply With Quote
Old   October 4, 2021, 05:49
Default alphaEqn.H has a bug
Rahul Subburaj
Originally Posted by ArminAlavi View Post
Hello Dongyue
Dear Armin,
I found a way to fix this issue. Change the nAlphaSubCycles in fvSolution to 1. Apparently having more than 1 subcycles defaults the ddtalphac to zero. Hope this helps!
Best regards,
Rahul Subburaj
Does pressure drop equals the dissipation within the fluid domain Onze Main CFD Forum 0 December 25, 2016 02:38
How to get motionU_ liu OpenFOAM Running, Solving & CFD 18 June 20, 2007 14:34
