Salome to foam import failing quality check
Old   July 26, 2017, 13:17
Smile Salome to foam import failing quality check
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Hi All,
I am trying to import SALOME mesh for a simple case (plate with hole) to OpenFoam, my geometry contails multiple parts and I have generated these parts with extrusion operation as shown in attached image. After converting this mesh to OpenFoam format using ideasUnvToFoam and while checking quality using checkMesh it is showing an error Failed 1 mesh checks. When I generate the mesh by keeping only one part, it is passing the quality check and I am able to run the case.
What additional operations I need to do in SALOME mesh module before exporting multibody part so that it pass the mesh check.
https://ibb.co/fhD8Kk
Thank you in advance
sunilpatil is offline   Reply With Quote
Old   August 2, 2017, 02:00
Nguyen Ngoc Thoai
NTVN96 is on a distinguished road
Hi sunilpatil!
Can you show errors from your checkMesh?
NTVN96 is offline   Reply With Quote
Old   August 2, 2017, 12:59
Smile Failed 1 mesh checks for salome to openFoam
sunilpatil's Avatar
sunil
Hi, The following error I am getting
suneel@suneel:~/OpenFOAM/suneel-3.0.1/run/tutorials/stressAnalysis/solidDisplacementFoam/plateHoleSalome$ checkMesh
| \\ / O peration | Version: 3.0.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 3.0.1-d8a290b55d28
Exec : checkMesh
Date : Aug 02 2017
Time : 21:27:03
Host : "suneel"
PID : 14333
Case : /home/suneel/OpenFOAM/suneel-3.0.1/run/tutorials/stressAnalysis/solidDisplacementFoam/plateHoleSalome
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
internal points: 1458
faces: 4070
internal faces: 1930
cells: 1000
faces per cell: 6
boundary patches: 6
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 1000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
***Unused points found in the mesh, number unused by faces: 1458 number unused by cells: 1458
<<Writing 1458 unused points to set unusedPoints
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
hole 20 42 ok (non-closed singly connected)
left 30 62 ok (non-closed singly connected)
down 30 62 ok (non-closed singly connected)
right 30 62 ok (non-closed singly connected)
up 30 62 ok (non-closed singly connected)
frontAndBack 2000 2142 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-1.46549e-16 2.27374e-15 0) (2 2 0.1)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-1.35489e-17 -1.96511e-18 3.01231e-16) OK.
Max cell openness = 1.76879e-16 OK.
Max aspect ratio = 3.15467 OK.
Minimum face area = 0.00205951. Maximum face area = 0.00785202. Face area magnitudes OK.
Min volume = 0.000205951. Max volume = 0.000445561. Total volume = 0.380385. Cell volumes OK.
Mesh non-orthogonality Max: 41.2645 average: 10.1358
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.422833 OK.
Coupled point location match (average 0) OK.
End
Old   August 3, 2017, 10:08
Smile
Nguyen Ngoc Thoai
This is your mesh's error:
Maybe some points are not defined in face or boundary!
You should check your Salome file!
Show it here, maybe I can help u!
multibody part, salome meshing
[Salome] Salome import "Cannot find file "points" in directory..." mismichael OpenFOAM Meshing & Mesh Conversion 6 June 24, 2024 04:17
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
