flotingObject case doesn't run when I change the dynamicMeshDict file. |
July 6, 2017, 22:02 |
Rep Power: 9 |
Hi, Foamers! I have met an anxious problem. Please give me your hands.
I have changed the case of floatingObject in the OF-3.0.1. Firstly I define a box in the topoSetDict. And then I make some changes in the dynamicMeshDict. I use the solidBodyMotionFvMesh, and define a linearMotion function, like that dynamicFvMesh solidBodyMotionFvMesh; solidBodyMotionFvMeshCoeffs { cellSet c0; solidBodyMotionFunction linearMotion; linearMotionCoeffs { velocity (0.5 0.5 0); } } But when I run the case, some error messages occur, the error information is "--> FOAM FATAL ERROR: Illegal content 286695 of set:c0 of type cellSet Value should be between 0 and 286694" And when i paraFoam the case, i see a terrible surface of floatingObject defined in the topoSetDict. If i don't change the dynamicMeshDict, just like the tutorials in of-3.0.1, the case can be run well. And the floatingObject is normal. Last edited by saatt; July 9, 2017 at 09:25. |
July 9, 2017, 09:26 |
Rep Power: 9 |
Anyone can help me? Please!!!
dynamicmeshdict |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 04:04 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
