simpleFoam BC's not working for interFoam
Old   July 2, 2017, 14:41
Default simpleFoam BC's not working for interFoam
Ashok
ashokmoravaneni is on a distinguished road
Good evening everyone,
I have an Assignment to simulate a sliding pipe test. I would like to briefly explain what I am supposed to do.
I have a cylindrical Geometry of 0.126m dia and 0.5m height. Patches are top-atmosphere or can also be considered wall, bottom-wall, sides-movingwall with velocity of 0.667m/s.
This case was done in simpleFOAM and the Results are perfectly accepted by my Professor. Now I was asked to implement this in interFoam where Im facing problem.
I have inputted the same Boundary conditions as i inputted in simplefoam for interfoam too but getting following error.
continuity error cannot be removed by adjusting the outflow. Run potentialfoam to initialize the outflow.
Bc's are as below,
SimpleFOAM case:
P
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
wall
type zeroGradient;
bottom
type zeroGradient;
top
type zeroGradient;
//If outflow
// type fixedValue;
// value $internalField;
U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
wall
type fixedValue;
value uniform (0 -0.6679 0);
bottom
type fixedValue;
value uniform (0 0 0);
top
type fixedValue;
InterFoam case:
P_rgh
dimensions [1 -1 -2 0 0 0 0];
boundaryField
movingWall
type zeroGradient;
// p0 uniform 0;
atmosphere
type zeroGradient;
bottomWall
type zeroGradient;
U:
boundaryField
movingWall
type fixedValue;
atmosphere
type fixedValue;
bottomWall
type fixedValue;
Could there be any other Reasons for such error.??
Will be looking forward for any kind of suggestions.Thank you
ashokmoravaneni is offline   Reply With Quote
How to setup cyclic BCs in simpleFOAM hhuang84 OpenFOAM Running, Solving & CFD 14 December 8, 2016 12:39
MPI error with simpleFoam blaise OpenFOAM Running, Solving & CFD 0 November 7, 2015 15:01
simpleFoam parallel solver & Fluent polyhedral mesh Zlatko OpenFOAM Running, Solving & CFD 3 September 26, 2014 07:53
Difference between HF and Temperature BCs Catthan FLUENT 0 August 7, 2013 06:59
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 12:58
