OpenFOAM Mac terminal cannot execute openfile command
Old   June 30, 2017, 08:54
Default OpenFOAM Mac terminal cannot execute openfile command
Haozhong Jiang
evojiang is on a distinguished road
Dear All,
I have a problem with running external shell script inside OpenFOAM, and I spent several days on it but still not fixed.
Here is the problem.
I wrote a C++ code to read the data from a local .txt file.
Here is the .cpp file:
#include <iostream>
#include <fstream>
#include <string>
using namespace std;
int main()
string line;
size_t pos = 0;
string token;
const char * V;
cout << "Starts" <<endl;
ifstream vMyFile;
vMyFile.open("/Users/Desktop/laminarVortexShedding/postProcessing/probes/0/U", std::fstream::in);
if (vMyFile.is_open())
int i = 0;
while (! vMyFile.eof() )
getline(vMyFile,line);
if (i >= 3)
if (line.find("(") == 28)
pos = line.find("(");
token = line.erase(0, pos);
// pos = token.find(" ");
// token = token.substr(0, pos);
//cout << "i = " << i << token << endl;
i++;
vMyFile.close();
V = token.c_str();
cout << "Last iteration velocity: " << V << endl;
else cout << "Unable to open file11111" << endl;
ofstream vEstimate_file ("/Users/Desktop/laminarVortexShedding/U_estimate");
if (vEstimate_file.is_open())
vEstimate_file << V;
vEstimate_file.close();
else cout << "Unable to open file22222" << endl;
return 0;
And then I made a shell script which compile the C++ code and ./run the program.
#!/bin/bash
# My first script
g++ -std=c++11 -o runf main.cpp
./runf
In the terminal, I type ./shell.sh, everything works fine and I get the result I want.
However, once I do the exact same thing in the OpenFOAM terminal window(Because OF on Mac is based on Docker? therefore I have to run it in a different terminal window, which has ofuser@98032082cf7e on the left.), it shows cannot open file.
Can anyone give me some help on this problem? Why it won't work on the OpenFOAM terminal?
Thanks a lot!
evojiang is offline   Reply With Quote
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 16:54
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
Is it a good idea to use OpenFoam on a Mac (OS 10.7.5) or on Windows7? bzz77 OpenFOAM Installation 4 November 21, 2012 18:06
