particle velocity field from twoPhaseEulerFoam when particle volume fraction is low
Old   June 28, 2017, 19:51
Default particle velocity field from twoPhaseEulerFoam when particle volume fraction is low
openfoammaofnepo is on a distinguished road
In twoPhaseEulerFoam, when the particle volume fraction is very low, less than the residual alpha, the particle velocity field is very strange. I did a test with zero particle volume fraction, there is only gas flow. In this case, I can get the same particle velocity field as that for the particle. This is not right, is it? The particle velocity should be zero everywhere.
best,
OFFO
openfoammaofnepo is offline   Reply With Quote
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Continous, multiple DPM injections to approximate particle volume fraction mkamalhilmi FLUENT 0 June 30, 2014 18:55
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
