June 28, 2017, 19:19 |
flowOverCyclinderAndItsUnderlyingMath
Ran
Rep Power: 10 |
Hi there:
I have two questions regarding with the relation between boundary/intial conditions and the global matrix. Question1:What is the size of Matrix A (see attached file, from Moukalled 2015)? Question2: How many unknown number are there? To give you more information with this question, I want use the benchmark example: flow over a circular cylinder. -version: OpenFOAM v4.1. -application: pisoFoam -geometry: see attached picture (Yeon, Seong Mo 2014 PHD Thesis) -checkMeshResut: see attached file -boundary/initial condition: see attached file -turbulent model: LES,kEqn see attached file I also think time step should be included in the discussion. Here, I just want to make it sample. Let's assume we just finish one time step, 0.001s. -P.S. please let me known if you need further information. Best regards, Ran Attach file: matrix.png coord.png geo.png /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : checkMesh Date : Jun 28 2017 Time : 17:53:43 Host : PID : 15901 Case : nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 5100480 faces: 15045220 internal faces: 14790380 cells: 4972600 faces per cell: 6 boundary patches: 5 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 4972600 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology INLET 10810 11088 ok (non-closed singly connected) OUTLET 10810 11088 ok (non-closed singly connected) CYLINDER 21620 22080 ok (non-closed singly connected) FRONT_CYC 105800 106260 ok (non-closed singly connected) BACK_CYC 105800 106260 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-20 -20 0) (20 20 3.1396) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-4.50402e-17 2.18592e-18 9.74372e-16) OK. Max cell openness = 3.11523e-16 OK. Max aspect ratio = 75.1683 OK. Minimum face area = 6.12404e-06. Maximum face area = 0.145038. Face area magnitudes OK. Min volume = 4.09086e-07. Max volume = 0.00968854. Total volume = 3942.75. Cell volumes OK. Mesh non-orthogonality Max: 0.106719 average: 0.00668153 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.0172544 OK. Coupled point location match (average 8.88178e-16) OK. Mesh OK. End \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\\\ k file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0.001"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { INLET { type fixedValue; value uniform 2e-05; } OUTLET { type inletOutlet; inletValue uniform 0; value uniform 0; } CYLINDER { type fixedValue; value uniform 0; } FRONT_CYC { type cyclic; } BACK_CYC { type cyclic; } } // ************************************************** *********************** // U file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0.001"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { INLET { type turbulentInlet; fluctuationScale (0.02 0.01 0.01); referenceField uniform (1.5 0 0); alpha 0.1; value uniform (1.5 0 0); } OUTLET { type zeroGradient; } CYLINDER { type noSlip; } FRONT_CYC { type cyclic; } BACK_CYC { type cyclic; } } // ************************************************** *********************** // nuTilda file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0.001"; object nuTilda; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { INLET { type fixedValue; value uniform 0; } OUTLET { type inletOutlet; inletValue uniform 0; value uniform 0; } CYLINDER { type fixedValue; value uniform 0; } FRONT_CYC { type cyclic; } BACK_CYC { type cyclic; } } // ************************************************** *********************** // nut file: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0.001"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { INLET { type zeroGradient; } OUTLET { type zeroGradient; } CYLINDER { type zeroGradient; } FRONT_CYC { type cyclic; } BACK_CYC { type cyclic; } } // ************************************************** *********************** // p file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0.001"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { INLET { type zeroGradient; } OUTLET { type fixedValue; value uniform 0; } CYLINDER { type zeroGradient; } FRONT_CYC { type cyclic; } BACK_CYC { type cyclic; } } // ************************************************** *********************** // s file /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0.001"; object s; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { INLET { type fixedValue; value uniform 1; } OUTLET { type inletOutlet; inletValue uniform 0; value uniform 0; } CYLINDER { type zeroGradient; } FRONT_CYC { type cyclic; } BACK_CYC { type cyclic; } } // ************************************************** *********************** // turbulence file: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // simulationType LES; LES { LESModel kEqn; turbulence on; printCoeffs on; delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } PrandtlCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Cdelta 0.158; } vanDriestCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } Aplus 26; Cdelta 0.158; } smoothCoeffs { delta cubeRootVol; cubeRootVolCoeffs { deltaCoeff 1; } maxDeltaRatio 1.1; } } // ************************************************** *********************** // |
