Unstable results in steady state solver
Old   June 28, 2017, 15:33
Default Unstable results in steady state solver
Ali
Alilo is on a distinguished road
Dear friends,
I'm using SimpleFoam solver. As you probably know, simpleFoam is steadystate solver, but when I simulate my model I saw unstable response and I have oscillation.
I've checked all boundary conditions and grid.
My question is that, what should I do to see stable results?
Appreciate.
Alilo is offline   Reply With Quote
Old   December 4, 2020, 04:00
Fritz Nieborowski
fritznieb is on a distinguished road
If your geometry is creating a turbulent wake for example, it is quite possible there is no "one steady solution".
For a rough guess general geometry (sharp edges), courantnumber, Reynoldsnumber might be a good idea to look at.
Also the iteration time step(assuming that you are using openfoam) might be a good place to vary.
Sorry for the vague answer but that's what I in general would look at based on the question.
Good luck
fritznieb is offline   Reply With Quote
Old   December 4, 2020, 07:08
Tobermory will become famous soon enough
Just to expand on fritznieb's response - if the flow solution is not steady, then there is no steady solution. Think of vortex shedding behind a cylinder for example - steady oncoming flow, but an unsteady wake flow as fritznieb describes. With a very coarse mesh, you might smooth out the unsteadiness through numerical diffusion; but the more accurate you make the modelling, the less artificial stability is introduced into the model and any unsteadiness in the solution will start to express itself through a limit-cycle type of behaviour.
To get the "steady" behaviour, or more accurately a time-averaged set of results, you'd need to run as transient and then field average over a sufficient number of periods of cycle.
What is the flow that you're trying to simulate, out of interest?
Tobermory is offline   Reply With Quote
result, simplefoam, stable, steadystate
Steady State solver for High Mach No flows mecbe2002 OpenFOAM 10 July 6, 2021 04:56
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Is steady state solver grid dependent? mmkr825 OpenFOAM 4 March 22, 2013 13:46
convergence issues on steady state solver icemaniac178 CFX 1 March 30, 2011 20:11
Physical time step for steady state solver Marcin OpenFOAM 0 July 2, 2009 03:20
