June 23, 2017, 08:43 |
Foam::error::printStack(Foam::Ostream&)
SAIKIRAN
Hello Foamers,
I am currently working on fluid flow in a rectangular case with electrodes placed inside (these are placed in such a way that the fluid travels in between the electrodes in zig zag manner). I am working in 3D with steady flow and the solver used is simpleFoam. while i am simulating the iterations are been stopped at 6 and showing the error as below. Time = 6 smoothSolver: Solving for Ux, Initial residual = 0.993905, Final residual = 0.0858968, No Iterations 9 smoothSolver: Solving for Uy, Initial residual = 0.982857, Final residual = 0.0847699, No Iterations 9 smoothSolver: Solving for Uz, Initial residual = 0.998165, Final residual = 0.0865682, No Iterations 9 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? at ??:? Floating point exception (core dumped) ************************************************** ************************************************* ************************************************** ************************************************* please have a look on checkMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : dev-f1240a853c45 Exec : checkMesh Date : Jun 23 2017 Time : 13:14:24 Host : "Gens-CFD" PID : 29762 Case : /home/linux/Pictures/pitzDaily nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 705079 internal points: 76213 faces: 4696956 internal faces: 3439228 cells: 2034046 faces per cell: 4 boundary patches: 6 point zones: 0 face zones: 1 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 2034046 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 3584 1881 ok (non-closed singly connected) outlet 3584 1881 ok (non-closed singly connected) front_and_back 324960 169714 ok (non-closed singly connected) topandbottom 86976 45079 ok (non-closed singly connected) fixedwalls 446496 227785 ok (non-closed singly connected) heater 392128 199979 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-4.74551e-18 0 0) (0.28 0.165 0.045) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-5.53563e-15 1.08718e-18 -2.6387e-18) OK. Max cell openness = 7.11546e-16 OK. Max aspect ratio = 17.575 OK. Minimum face area = 2.5745e-08. Maximum face area = 0.000120768. Face area magnitudes OK. Min volume = 2.75791e-12. Max volume = 3.55206e-07. Total volume = 0.0018765. Cell volumes OK. Mesh non-orthogonality Max: 77.679 average: 31.9159 *Number of severely non-orthogonal (> 70 degrees) faces: 883. Non-orthogonality check OK. <<Writing 883 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.11575 OK. Coupled point location match (average 0) OK. Mesh OK. End ************************************************** ************************************************* ************************************************** ************************************************* can anyone please help me out. Thanks Sai |
