HR Scheme inplementation in OpenFOAM
Old   June 22, 2017, 07:30
Default HR Scheme inplementation in OpenFOAM
Nuno Enes
NRAE is on a distinguished road
Hi everyone,
For a while now I have been interested to understand how the QUICK scheme is implemented in OpenFOAM. I gathered so far (please correct me if I am wrong) that it is formulated as a TVD scheme such that the flux at face phi_f is,
phi_f = phi_C + 0.5*psi(r)*(phi_D - phi_C)
where the subscripts f,C and D correspond to the values at the face, the upwind node (relative to the face) and the downwind node respectively.
However when I read the code in "QUICK.H" where the limiter is defined i find,
phiCD = cdWeight*phiP + (1 - cdWeight)*phiN;
phif = 0.5*(phiCD + phiP + (1 - cdWeight)*(d & gradcP));
and the limiter which I assume is given by QLimiter
psi(r)=QLimiter = (phif - phiU)/stabilise(phiCD - phiU, SMALL);
In OpenFOAM notation I think node C = P and D = N (for the case of east-bound flow)
I am puzzled by this. I suspect phi_f is being calculated via QUICK scheme's gradient form,
phi_f = phi_C + 0.5*(nabla(phi_C) + nabla(phi_f)).d_Cf
But that is where I am at.
Could somebody enlighten me?
Thank you!
NRAE is offline   Reply With Quote
interpolation, quick, scheme
OpenFOAM Training Beijing 22-26 Aug 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 May 3, 2016 05:57
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 cfd.direct OpenFOAM Announcements from Other Sources 0 January 5, 2016 04:18
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
numerical scheme in openfoam seju OpenFOAM Pre-Processing 3 May 31, 2014 11:08
Parameter for the cubic upwind scheme in OpenFOAM JinBiao OpenFOAM 1 May 23, 2010 04:51
