MRFSimpleFoam simulate centrifugal pump
Old   June 8, 2017, 07:47
Default MRFSimpleFoam simulate centrifugal pump
jock is on a distinguished road
Hi foamers
I meet some questions about simulation of centrifugal pump ,I can not output its head and efficiency.
Who's gonna send me this program?
thank you
jack
jock is offline   Reply With Quote
Old   June 9, 2017, 09:51
Antti Heino
anttiad9000 is on a distinguished road
Hello jack,
I do this by using swak4Foam and an the built-in forces function. Once you have installed the swak4Foam add these lines to your controlDict:
libs
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
"libforces.so" // this is for forces
functions
    forces
        type forces;
        outputControl timeStep;
        outputInterval 1;
        enabled true;
        patches
            add_all_wetted_rotating_hydraulic_surfaces_here
        rhoName rhoInf;
        log true;
        rhoInf add_fluid_density_here;
        CofR (0 0 0);
    totalHead
        type expressionField;
        outputInterval 1;
        fieldName Htot;
        redirectType Htot;
        expression "p/9.81+pow(mag(U),2)/(2*9.81)";
        autowrite true;
        dimension [0 1 0 0 0 0 0];
    Himpeller
          type patchExpression;
          outputControlMode timeStep;
          outputInterval 1;
          enabled true;
          variables
               "Houtlet{add_impeller_outlet_patch_here}=sum(phi*Htot)/sum(phi);"
               "Hinlet{add_impeller_inlet_patch_here}=sum(phi*Htot)/sum(phi);"
          patches
               add_one_of_the_patches_here
          expression "Houtlet-Hinlet";
          verbose true;
          allowCoupled true;
          accumulations ( average );
With these functions force and torque components will be printed to the log and also to separate file every timestep. The same happens with head. You get the inlet power by multiplying torque in shaft direction with angular velocity, omega. The efficiency is calculated with the equation eta = (rho*g*Q*H)/(Pinlet). I hope this helps.
If you already have already finished you simulation, add the lines above to your controlDict and run one more time-step to get the output.
Also, if you do not have swak4Foam or don't want to install it for some reason you could also grep the data from result fields manually or by creating a script. Though, the method above is a much simpler approach.
P.S. There might be typos as I did not test it. Also remember to replace the patch names.
I hope this helps you,
Antti
anttiad9000 is offline   Reply With Quote
Old   June 9, 2017, 11:28
Thank you,Antti. I see.
I have some other questions.
I want to monitor the inlet and outlet pressure during the simulation. What should I do?May I use "foamCalc"?
thank you for much.
jack
Old   June 13, 2017, 04:33
Antti Heino
Hello jack,
To get proper monitors at every time step you can just change the Himpeller function from the previous post to two separate functions:
    Hinlet
          outputInterval 1;
          enabled true;
          variables
          patches
          expression "Hinlet";
          verbose true;
          allowCoupled true;
    Houtlet
          outputInterval 1;
          enabled true;
          variables
          patches
          expression "Houtlet";
          verbose true;
          allowCoupled true;
Personally, I have never used foamCalc but as far as I understand, foamCalc calculates a new field for a resolved timestep from another field. For example to get speed from velocity by calculating mag(U) from the field U. This would also mean that you have to save the data for each timestep you want to calculate it. It would not make sense here to use foamCalc.
Another point is that you need to calculate mass averaged value which reduces to volumetric average for incompressible flows which means that you have to combine two different fields which is exactly what the above function does with swak4Foam.
Antti
Old   June 13, 2017, 09:44
Hi Antti,
I am using swak4Foam,thank you for your help!
Jack
Old   June 15, 2017, 06:45
saleriCAE is on a distinguished road
is it possible to use swak4foam also for taking the flow rate through a ggi patch and through a desired section?
Thank you
saleriCAE is offline   Reply With Quote
Old   June 15, 2017, 07:07
Antti Heino
Hi saleriCAE,
Although this is a bit off-topic I will give you a simple answer. I assume that by 'taking the flow rate' you mean monitoring the flow rate through a certain patch. If so, yes, it is possible and very simple. swak4Foam is a very useful tool to learn that makes implementing all kinds of monitors possible. You could do this for example with this function:
    Qmonitor
          outputInterval 1;
          enabled true;
          patches
               patch_you_want_to_monitor
          expression "phi";
          verbose true;
          allowCoupled true;
          accumulations ( sum );
There are some differences to the function before as no new variables are needed here. Also, the accumulation is changed from average to sum as it is more appropriate in this case. In the last case it does not actually matter which one it is. Basically, the function just sums all the phi's on each patch face and outputs the sum to a file and, the log.
Hope this helps,
Antti
Old   June 15, 2017, 11:46
Hi Antti,
thank you for your reply.
What if I want to take the flow rate through an arbitrary section of the model?
Let us assume I have a pipe from z=0 (patch inlet) to z=100 (patch outlet) and I want to take the flow rate at z=50 (where I have no patch defined). Is it possible with swak4foam?
Thank you very much.
Old   June 15, 2017, 13:32
Antti Heino
Hello saleriCAE,
yes that is at least somewhat possible. I have done this once over a year ago by creating an stl-surface file and used a swak4Foam function with some modifications. There should be an option that uses face zones/sets, when you would have to define the zone/set, but I am not familiar with it. Other options might exist as well but I haven't used them.
Also, unfortunately I cannot remember how to set up the function from the top of my head and I don't have time now to research the issue. I suggest that you search swak4Foam guides and examples, for instance here http://openfoamwiki.net/index.php/Contrib/swak4Foam
Antti
Centrifugal Pump Simulation Problem! warex FloEFD, FloWorks & FloTHERM 29 September 23, 2014 11:27
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) ArianeJasmin OpenFOAM Programming & Development 1 April 4, 2012 15:11
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance barak182 ANSYS Meshing & Geometry 2 August 18, 2010 04:07
CFD analysis of centrifugal pump saurabh9978 FLUENT 0 March 21, 2010 13:07
how to simulate centrifugal pump? Alex FLUENT 0 February 21, 2006 17:35
