June 6, 2017, 13:42 |
PRefCell not constant
Charlie Lloyd
Rep Power: 10 |
Hi all,
I am simulating a fully developed channel flow using RANS and cyclic boundary conditions. In order to do so I need to specify a reference pressure at a certain location. I have chosen a cell on one of the wall boundaries to have a reference pressure of 0 BUT after checking the converged solution the pressure at this cell is 0.029. I assumed the reference cell would maintain the reference pressure throughout the whole simulation - is this not the case? Thanks in advance. |
June 11, 2017, 15:47 |
khedar
Rep Power: 10 |
Just wondering, is it okay to put reference cell on the wall? Since normally we apply zeroGradient condition on the wall.
June 11, 2017, 15:58 |
Charlie Lloyd
Rep Power: 10 |
I assumed that it wouldn't matter but you might be right. However, I'm not sure where else to put the reference point in a periodic channel. I need to be able to calculate forces on the wall so wouldn't they be dependent on the pressure field? And wouldn't changing the reference point subsequently change the force calculations?
Thanks for the reply. |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 06:38 |
fluid flow but temperature raises from nowhere? | mxcfd | STAR-CCM+ | 5 | September 16, 2014 06:46 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
Really big problems when creating own materials da | Jop | FLUENT | 0 | June 28, 2007 12:15 |
