channel flow - pisoFoam question
Old   June 5, 2017, 05:02
Default channel flow - pisoFoam question
Thao Nguyen
khunyeu is on a distinguished road
Dear Foamers,
I'm doing a scour channel flow with pisoFoam kOmegaSST, basically my BCs are as below, however numerical velocity result is not fit with experimental data (please see the attached figure).
I have y+ around 40 so I used wallFuntion at the bottom.
I have tried with many other BCs for U and p --> not better
changed fvSchemes to 2nd orders --> not better
changed to (much) finer mesh (checkMesh of both cases are OK) --> not better
The result is surprisingly good in scour hole but not good far the wall and far downstream, also my U at downstream is bigger than inlet velocity, which is wrong.
I'm not sure what to do to fix this, could anyone please have a look and any suggestion would be very appreciated.
0/U
inlet
        type            fixedValue;
        value           uniform (0.405 0 0);
    wall1
        type            fixedValue;
        value           uniform (0 0 0);
    lowerWall
        type            fixedValue;
    atmosphere
        type                zeroGradient;
    outlet
        type                zeroGradient;
    frontAndBack
        type            empty;
0/p
inlet
        type            zeroGradient;
    wall1
        type            zeroGradient;
    lowerWall
        type            zeroGradient;
    atmosphere
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform  0;
    frontAndBack
        type            empty;
0/k
inlet
        type            fixedValue;
        value           uniform 0.000615;
    outlet
        type            zeroGradient;
    wall1
        type            kqRWallFunction;
    lowerWall
    atmosphere
        type            zeroGradient;
    frontAndBack
        type            empty;
0/omega
inlet
        type            fixedValue;
        value           uniform 1.078;
    outlet
        type            zeroGradient;
    wall1
        type            omegaWallFunction;
        value           $internalField;
    lowerWall
    atmosphere
        type            zeroGradient;
    frontAndBack
        type            empty;
0/nut
inlet
        type            calculated;
        value             uniform 0;
    outlet
        type            calculated;
        value             uniform 0;
    atmosphere
        type            calculated;
        value             uniform 0;
    wall1
        type            nutkRoughWallFunction;
        value          uniform 0;
        Ks              uniform 0;
        Cs              uniform 0.5;
    lowerWall
        value          uniform 0;
        Ks              uniform 0.0012;
        Cs              uniform 0.5;
    frontAndBack
        type            empty;
Thank you in advance.
Min.
khunyeu is offline   Reply With Quote
Open channel flow with submerged outlet Fonta Fluent Multiphase 0 September 30, 2013 09:04
Modeling the mixing of air and kerosene in a flow channel StefanG CFX 3 June 11, 2012 21:21
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
gas flow out of a C-D channel ljp FLUENT 0 March 7, 2011 15:32
Flow Split Setup Question ed FLUENT 1 February 16, 2007 17:55
