cyclicAMI Interface
Old   June 3, 2017, 23:42
Default cyclicAMI Interface
wil
willindsey is on a distinguished road
I am trying to import a hybrid mesh from fluent into open foam. The mesh is a combination of hex and tet elements. Using facematch in ansys mesh I was able to create the same resolution and line up the faces. The tet interface has double the number of faces as the quad interface and I was wondering if I have set it up properly in openFoam or if there is a way to do it better. Thanks.
Poly mesh boundry:
tet-interface
type cyclicAMI;
nFaces 8568;
startFace 4156634;
neighbourPatch quad-interface;
transform noOrdering;
quad-interface
type cyclicAMI;
nFaces 4284;
startFace 4165202;
neighbourPatch tet-interface;
willindsey is offline   Reply With Quote
Old   June 4, 2017, 08:41
C-L
Charlie Lloyd
C-L is on a distinguished road
Have a look at the createPatch utility - if you leave the poly-mesh boundaries as patches and then run createPatch then OpenFOAM will rewrite the boundaries for you.
C-L is offline   Reply With Quote
Old   June 4, 2017, 12:28
wil
I executed this:
pointSync false;
patches
name tet-interface;
patchInfo
type cyclic;
constructFrom patches;
patches (tet-interface);
name quad-interface;
patchInfo
type cyclic;
patches (quad-interface);
Nothing seemed to have changed in my boundary file. What should I be looking for?
Old   June 4, 2017, 12:32
C-L
Charlie Lloyd
Have you checked the timestep directories? createPatch won't overwrite your mesh unless you specify -overwrite in the command. If it has executed properly then it will have written to a timestep directory instead.
ansys, cyclicami, interface, openfoam
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
