An interpolating problem in paraview
Old   May 31, 2017, 05:54
Default An interpolating problem in paraview
zzj
zhengzongji
zzj is on a distinguished road
Hi, dear foamers
I am working on the simulation of laser drilling. Everything went on well when I use a 2-D model (Picture01), but when it turns to 3-D I meet some problems.
Firstly, I think I need to introduce my model, the shape is a cube. Before drilling, the lower part is full of solid materials (aluminium) to be handled while upper half is full of air.
I redefine the solver (multiPhaseInterFoam) to deal with the case. So the parameter to differentiate different phase is alpha (phase fraction). When alpha is 0, it means the cell is full of air. 1 means liquid. 2means solid.
After drilling, I can hardly observe the surface topography in paraview because the air mask the lower part. Then I use function called threshold and set alpha visible when it ranges from 0.1 to 2 to ensure air is not visible. It is regrettable that some cells which contain both air and liquid are removed. The topography is too rough to be accepted (Picture02 is attached below).
So can anyone tells me how to interpolate the parameter or give some better advice?
Thanks.
ZZJ
zzj is offline   Reply With Quote
Old   May 31, 2017, 08:54
zzj
zhengzongji
Originally Posted by zzj View Post
Hi, dear foamers
Thanks.
ZZJ
Well, I find a button in paraview named enable opacity mapping for surface,
the scale near zero is crystal, but it only works on surface...
I have no idea about this, could anyone helps me?
ParaView Execute problem insta OpenFOAM Installation 2 June 9, 2014 03:37
[General] Problem in using paraview meballav ParaView 11 October 12, 2012 17:03
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 19:13
Yet another Paraview problem gascortado OpenFOAM 5 February 21, 2010 07:39
[OpenFOAM] Problem with Colors in ParaView sven ParaView 1 May 31, 2009 09:13
