May 27, 2017, 11:13 |
mixing hot cold water
arianna sterpi
Rep Power: 9 |
Hi everybody!
I would like to simulate a pipe flow with two inflows ( first inflow cold 10 °; second inflow 54°C) and one outflow with the mixture of both (at 37°C). I'm using icoFoam solver modified to solve temperature equation. The inlet where I have hot water, which enter at a velocity of 0.026 m/s, is inclined at an angle of 110°. - Do I have to decompose the velocity along the axis, to enter it in the 0/U file? - which kind of pressure bundaries I have to use? - which kind of physicalProperties do I have to use? Thermal diffusivity and kinematic viscosity at which water temperature? Sorry for the elevate number of question... i'm new to OpenFoam!! thank you very much |
boundaries condition, mixing hot and cold water |
chlorination mixing with water | marwa | FLUENT | 4 | December 24, 2019 14:07 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
Mixing Problem in Double Pipe Heat Exchanger With Fluid Fluid Interface | Shomaz ul Haq | CFX | 3 | December 17, 2015 13:50 |
Convection in a hot water tank | Marie13 | FLUENT | 5 | April 2, 2013 17:39 |
Hot gas bubble collapse in cool water | William Palm | FLUENT | 1 | April 20, 2005 11:53 |
