k not being convected
Old   May 26, 2017, 14:01
Default k not being convected
LR
sabuj is on a distinguished road
Send a message via Skype™ to sabuj
Dear all,
I am trying to simulate VAWT with pimpleDyMFoam on fe32 with k-epsilon turbulence model. But k is not being convected and keeps trailing the airfoils instead (image attached). Has anyone faced this problem before? Please help
Thanks,
LR
sabuj is offline   Reply With Quote
Old   May 27, 2017, 13:09
Kanuk
kanuk is on a distinguished road
I have had the same problem before and did not have any luck in solving it unfortunately...
For what it's worth, I did notice that, for some reason, the Spalart-Allmaras turbulence model for fe32 does convect turbulent eddy viscosity downstream properly. Various other two-equations models (including k-w-SST) did not work for me though. Hopefully you can find your answers here!
kanuk is offline   Reply With Quote
Old   September 20, 2019, 11:32
Default possible solution:
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
I had the same issue and I solved it by using
minIter    1;
on my turbulence residuals (k and omega in my case) in fvSolution.
The reason being that the initial residuals on the turbulence equations was already lower than my tolerance and the solver would consequently not solve it!
I got my solution from this post: Problem with SST-Model - strange behaviour
louisgag is offline   Reply With Quote
calcFvcGrad Nico A. OpenFOAM Post-Processing 26 April 7, 2022 11:19
Boundary conditions for S2S radiation model in naturally convected square cavity Mahendra_Paipuri FLUENT 1 October 17, 2014 06:46
Problems in representing convected derivatives in OpenFoam titio OpenFOAM Running, Solving & CFD 1 February 16, 2009 16:01
Pressure checkerboard problem behzad Main CFD Forum 7 July 4, 2005 11:51
