OpenFOAM parallel run processor error
Old   May 24, 2017, 15:51
Default OpenFOAM parallel run processor error
Oğuzhan Demir
ddemiroguzhan is on a distinguished road
Hi everyone,
I am trying to run a parallel simulation in OpenFOAM. When i choose 56 processors, i get the following error. When i use 28 processors, it works just fine. But for some reason, i can not use 56 processors for analysis.
''/***/***/***/***/system/decomposeParDict" specifies 56 processors but job was started with 28 processors.
Is there anyone who could help me with this problem?
Thx in advance.
Oguz
ddemiroguzhan is offline   Reply With Quote
Old   May 26, 2017, 13:28
Collin Strassburger
Collin is on a distinguished road
I have had issues like that when the mpi instance was not properly configured on the cluster. If you're running this through a scheduler, I suggest ensuring that the number of cores you're telling openfoam to use is identical to the number of cores requested from the scheduler. Furthermore, you may need to check if the cluster/scheduler can reliably do mpi runs across any number of nodes/cores.
Collin is offline   Reply With Quote
Old   May 26, 2017, 13:32
Oğuzhan Demir
Hi Collin,
Thank you for the suggestion. As you have mentioned, I was running the simulation on a cluster. After re-installing the mpi, my problem has resolved and now i can run simulations properly.
Oguz
decomposepar, error, openfoam, parallel
[OpenFOAM] Questions about Paraview to show Parallel run of OpenFOAM padian ParaView 20 September 24, 2018 13:52
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
unable to run in parallel with OpenFOAM 2.2 on CentOS einatlev OpenFOAM Running, Solving & CFD 9 June 26, 2014 01:24
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 04:26
