Floating issue when running openfoam through grasshopper |
May 22, 2017, 06:27 |
JIN WEIGUO
Rep Power: 10 |
Dear Openfoam experts,
I have a flaoting issue when running buoyantBoussinesqSimpleFoam through grasshopper. Can anyone help tell how can I solve it? Many thanks. Mark /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1612+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1612+ Exec : buoyantBoussinesqSimpleFoam -parallel Date : May 22 2017 Time : 10:18:58 Host : "default" PID : 2839 Case : /home/ofuser/workingDir/butterfly/simple_hvac nProcs : 4 Slaves : 3 ( "default.2840" "default.2841" "default.2842" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field nut tolerance 0.0001 field p_rgh tolerance 0.0001 field k tolerance 0.0001 field U tolerance 0.0001 field T tolerance 0.0001 field epsilon tolerance 0.0001 field alphat tolerance 0.0001 Reading thermophysical properties Reading field T Reading field p_rgh Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model RNGkEpsilon RNGkEpsilonCoeffs { Cmu 0.0845; C1 1.42; C2 1.68; C3 -0.33; sigmak 0.71942; sigmaEps 0.71942; eta0 4.38; beta 0.012; } Reading field alphat Reading g Reading hRef Calculating field g.h No MRF models present Radiation model not active: radiationProperties not found Selecting radiationModel none No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.06427477, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.06226344, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 0.03950103, No Iterations 3 smoothSolver: Solving for T, Initial residual = 1, Final residual = 0.03671111, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 0.008356878, No Iterations 86 DICPCG: Solving for p_rgh, Initial residual = 0.07888434, Final residual = 0.0006831407, No Iterations 9 DICPCG: Solving for p_rgh, Initial residual = 0.007053905, Final residual = 6.211827e-05, No Iterations 71 time step continuity errors : sum local = 3777.266, global = 3.22967, cumulative = 3.22967 smoothSolver: Solving for epsilon, Initial residual = 0.9994728, Final residual = 0.0532353, No Iterations 4 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.05640973, No Iterations 4 ExecutionTime = 2.65 s ClockTime = 3 s Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.5142984, Final residual = 0.02186577, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.5242573, Final residual = 0.02244622, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.5106874, Final residual = 0.02933279, No Iterations 2 smoothSolver: Solving for T, Initial residual = 0.3832824, Final residual = 0.01046751, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.9825413, Final residual = 0.009757923, No Iterations 799 DICPCG: Solving for p_rgh, Initial residual = 0.04390194, Final residual = 0.000303611, No Iterations 9 DICPCG: Solving for p_rgh, Initial residual = 0.0073043, Final residual = 7.259574e-05, No Iterations 45 time step continuity errors : sum local = 1883567, global = 2227.205, cumulative = 2230.435 smoothSolver: Solving for epsilon, Initial residual = 0.08647006, Final residual = 0.000113174, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.1579946, Final residual = 0.01115579, No Iterations 2 ExecutionTime = 9.56 s ClockTime = 10 s Time = 3 smoothSolver: Solving for Ux, Initial residual = 0.8070853, Final residual = 0.07865708, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 0.8145663, Final residual = 0.03882168, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.5761609, Final residual = 0.0390739, No Iterations 4 smoothSolver: Solving for T, Initial residual = 0.1644957, Final residual = 0.006771158, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.7802636, Final residual = 0.006709539, No Iterations 13 DICPCG: Solving for p_rgh, Initial residual = 0.04575494, Final residual = 0.0004415382, No Iterations 130 DICPCG: Solving for p_rgh, Initial residual = 0.005830491, Final residual = 5.648426e-05, No Iterations 78 time step continuity errors : sum local = 6.68889e+12, global = -4.053656e+11, cumulative = -4.053656e+11 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.08337707, No Iterations 1 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.08762031, No Iterations 2 ExecutionTime = 11.24 s ClockTime = 11 s Time = 4 smoothSolver: Solving for Ux, Initial residual = 0.1870785, Final residual = 0.008250987, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.1039591, Final residual = 0.003633928, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.003344756, Final residual = 0.0001428352, No Iterations 2 smoothSolver: Solving for T, Initial residual = 0.0360337, Final residual = 0.0008781286, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.9999995, Final residual = 0.7505781, No Iterations 1001 DICPCG: Solving for p_rgh, Initial residual = 2.097918e-11, Final residual = 2.097918e-11, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 2.097918e-11, Final residual = 2.097918e-11, No Iterations 0 time step continuity errors : sum local = 9.100777e+16, global = -1.152626e+15, cumulative = -1.153031e+15 smoothSolver: Solving for epsilon, Initial residual = 0.006323925, Final residual = 0.0002800085, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.9999998, Final residual = 0.08579136, No Iterations 4 ExecutionTime = 15.48 s ClockTime = 16 s Time = 5 smoothSolver: Solving for Ux, Initial residual = 0.6268107, Final residual = 0.01889084, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.5691313, Final residual = 0.02593386, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.525286, Final residual = 0.01999095, No Iterations 2 smoothSolver: Solving for T, Initial residual = 0.1776883, Final residual = 0.004896742, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.8409992, Final residual = 0.008296552, No Iterations 25 DICPCG: Solving for p_rgh, Initial residual = 8.57445e-13, Final residual = 8.57445e-13, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 8.57445e-13, Final residual = 8.57445e-13, No Iterations 0 time step continuity errors : sum local = 3.230307e+23, global = -5.044393e+14, cumulative = -1.657471e+15 smoothSolver: Solving for epsilon, Initial residual = 4.732135e-05, Final residual = 1.311093e-10, No Iterations 1 bounding epsilon, min: -1.103807e+26 max: 1.972571e+51 average: 2.670218e+47 smoothSolver: Solving for k, Initial residual = 0.04771126, Final residual = 0.002285774, No Iterations 2 ExecutionTime = 16.44 s ClockTime = 17 s Time = 6 smoothSolver: Solving for Ux, Initial residual = 0.9995642, Final residual = 0.04432588, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.9996968, Final residual = 0.04761556, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.9858131, Final residual = 0.06924769, No Iterations 3 smoothSolver: Solving for T, Initial residual = 0.01200576, Final residual = 0.0002952721, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.9446084, Final residual = 0.005339222, No Iterations 6 DICPCG: Solving for p_rgh, Initial residual = 0.08971123, Final residual = 0.0008218812, No Iterations 6 DICPCG: Solving for p_rgh, Initial residual = 0.02323654, Final residual = 0.0002319251, No Iterations 193 time step continuity errors : sum local = 4.926861e+44, global = -1.110593e+37, cumulative = -1.110593e+37 smoothSolver: Solving for epsilon, Initial residual = 1, Final residual = 0.002671469, No Iterations 2 bounding epsilon, min: -2.219668e+47 max: 1.75779e+78 average: 3.182358e+73 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0501481, No Iterations 2 bounding k, min: -3.660183e+25 max: 9.966186e+62 average: 8.53815e+58 ExecutionTime = 18.1 s ClockTime = 18 s Time = 7 smoothSolver: Solving for Ux, Initial residual = 8.069155e-09, Final residual = 8.069155e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 5.382338e-08, Final residual = 7.473481e-09, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 2.092083e-08, Final residual = 2.077615e-09, No Iterations 1 smoothSolver: Solving for T, Initial residual = 0.1619372, Final residual = 0.003564584, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 46631.37, No Iterations 1001 DICPCG: Solving for p_rgh, Initial residual = 1.64537e-26, Final residual = 1.64537e-26, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 1.64537e-26, Final residual = 1.64537e-26, No Iterations 0 time step continuity errors : sum local = 1.468529e+53, global = 5.868436e+40, cumulative = 5.867326e+40 smoothSolver: Solving for epsilon, Initial residual = 0.07343377, Final residual = 2.828068e-19, No Iterations 1 bounding epsilon, min: -2.257804e+66 max: 8.093947e+109 average: 1.184346e+105 smoothSolver: Solving for k, Initial residual = 0.5212037, Final residual = 0.02939162, No Iterations 2 ExecutionTime = 22.26 s ClockTime = 22 s Time = 8 smoothSolver: Solving for Ux, Initial residual = 0.6924604, Final residual = 0.01784756, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.3637153, Final residual = 0.005737122, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.2793264, Final residual = 0.00626238, No Iterations 2 smoothSolver: Solving for T, Initial residual = 0.07790577, Final residual = 0.002676894, No Iterations 2 DICPCG: Solving for p_rgh, Initial residual = 0.8911507, Final residual = 0.008688155, No Iterations 18 DICPCG: Solving for p_rgh, Initial residual = 1.957294e-52, Final residual = 1.957294e-52, No Iterations 0 DICPCG: Solving for p_rgh, Initial residual = 1.957294e-52, Final residual = 1.957294e-52, No Iterations 0 time step continuity errors : sum local = 8.548233e+90, global = -3.056251e+75, cumulative = -3.056251e+75 -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 2840 on node default exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- [1] #0 Foam::error:rintStack(Foam::Ostream&)[0] #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [0] #2 ? in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [1] #2 ? in "/lib64/libc.so.6" [0] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib64/libc.so.6" [1] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [0] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so" [1] #4 void Foam::multiply<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so" [1] #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so" [1] #6 Foam::RASModels::RNGkEpsilon<Foam::IncompressibleT urbulenceModel<Foam::transportModel> >::correct() in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so" [1] #7 ? in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqSimpleFoam" [1] #8 __libc_start_main in "/lib64/libc.so.6" [1] #9 ? in "/opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/bin/buoyantBoussinesqSimpleFoam" [default:02840] *** Process received signal *** [default:02840] Signal: Floating point exception (8) [default:02840] Signal code: (-6) [default:02840] Failing at address: 0x1f400000b18 [default:02840] [ 0] /lib64/libc.so.6(+0x32660)[0x7f516d4f4660] [default:02840] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x7f516d4f45e5] [default:02840] [ 2] /lib64/libc.so.6(+0x32660)[0x7f516d4f4660] [default:02840] [ 3] /opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam8multiplyERNS_5FieldIdEERKN S_5UListIdEES6_+0xd5)[0x7f516e7bfd55] [default:02840] [ 4] /opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4Foam8mult iplyINS_12fvPatchFieldENS_7volMeshEEEvRNS_14Geomet ricFieldIdT_T0_EERKS6_S9_+0x41)[0x7f5172705861] [default:02840] [ 5] /opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4FoammlINS _12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14Geometr icFieldIdT_T0_EEEERKS7_RKS8_+0x15b)[0x7f5172784afb] [default:02840] [ 6] /opt/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/libincompressibleTurbulenceModels.so(_ZN4Foam9RASM odels11RNGkEpsilonINS_29IncompressibleTurbulenceMo delINS_14transportModelEEEE7correctEv+0x2d0)[0x7f51727d5ec0] [default:02840] [ 7] buoyantBoussinesqSimpleFoam[0x481a7d] [default:02840] [ 8] /lib64/libc.so.6(__libc_start_main+0xfd)[0x7f516d4e0d1d] [default:02840] [ 9] buoyantBoussinesqSimpleFoam[0x42db51] [default:02840] *** End of error message *** |
May 24, 2017, 21:04 |
JIN WEIGUO
Rep Power: 10 |
Anyone can help debug?
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
Random machine freezes when running several OpenFoam jobs simultaneously | 2bias | OpenFOAM Installation | 5 | July 2, 2010 07:40 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
divide by zero FPE issue in OpenFOAM 141 MingW port | allenzhao | OpenFOAM Installation | 9 | September 22, 2008 17:13 |
Adventure of fisrst openfoam installation on Ubuntu 710 | jussi | OpenFOAM Installation | 0 | April 24, 2008 14:25 |
