Reporting turbulence fields
Old   May 18, 2017, 02:20
Default Reporting turbulence fields
kaaja is on a distinguished road
I run openFoam 4.1, and have a problem extracting the turbulent stress tensor, R, in my k-eps simulation.
To extract R, I have only modified the controlDict, which looks like the following:
|  \\    /   O peration     | Version:  4.0                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
application     simpleFoam;
startTime       0;
stopAt          endTime;
endTime         5000;
deltaT          1;
writeControl    timeStep;
writeInterval   100;
purgeWrite      2;
writeFormat     ascii;
writePrecision  8;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
functions
#includeFunc    residuals
    turbulenceFields1
        type            turbulenceFields;
        libs            ("libfieldFunctionObjects.so");
        field           R;
When I try solving with the above controlDict, I get the following:
|  \\    /   O peration     | Version:  4.1                                   |
Build  : 4.1
Exec   : simpleFoam
Date   : May 18 2017
Time   : 07:08:01
Host   : "..."
PID    : 11073
Case   : /home...
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p     tolerance 0.001
    field U     tolerance 0.001
    field "(k|epsilon|omega|f|v2)"     tolerance 0.001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              -0.33;
    sigmak          1;
    sigmaEps        1.3;
No MRF models present
No finite volume options present
Starting time loop
turbulenceFields turbulenceFields1: storing fields:
    turbulenceProperties:R
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.068919891, No Iterations 6
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.094423261, No Iterations 4
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.065365879, No Iterations 6
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0086113464, No Iterations 26
time step continuity errors : sum local = 0.51812432, global = -0.07783965, cumulative = -0.07783965
smoothSolver:  Solving for epsilon, Initial residual = 0.59675441, Final residual = 0.051409907, No Iterations 3
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.092548244, No Iterations 2
ExecutionTime = 0.81 s  ClockTime = 1 s
--> FOAM FATAL ERROR:
object of type N4Foam9Function1INS_10SymmTensorIdEEEE is not allocated
    From function T* Foam::autoPtr<T>::operator->() [with T = Foam::Function1<Foam::SymmTensor<double> >]
    in file /home/ubuntu/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude/autoPtrI.H at line 176.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::timeVaryingMappedFixedValueFvPatchField<Foam::SymmTensor<double> >::write(Foam::Ostream&) const at ??:?
#3  Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>::Boundary::writeEntry(Foam::word const&, Foam::Ostream&) const at ??:?
#4  Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>::writeData(Foam::Ostream&) const at ??:?
#5  Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const at ??:?
#6  Foam::functionObjects::regionFunctionObject::writeObject(Foam::word const&) at ??:?
#7  Foam::functionObjects::turbulenceFields::write() at ??:?
#8  Foam::functionObjectList::execute() at ??:?
#9  Foam::Time::loop() at ??:?
#10  Foam::simpleControl::loop() at ??:?
#11  ? at ??:?
#12  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13  ? at ??:?
Aborted (core dumped)
So it seems like that openFoam solves for the first time step, and then something goes wrong. In the the catalog "1" there is now only a file "turbulenceProperties:R", which seams to containt the 6 elements of the stress tensor for each point.
Does anybody know how to fix this?
kaaja is offline   Reply With Quote
Old   May 24, 2017, 03:19
I think I found the answer, here.
turbulenceproperties
how to set URANS turbulence model in unsteady flow simulation TimLiu OpenFOAM Pre-Processing 0 April 25, 2017 09:52
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 15:18
Initial pressure and transverse velocity fields to initialize turbulence model nickvinn Main CFD Forum 0 February 29, 2012 11:11
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
