simpleF, S-A, no convergence, sphere in air at re10^4
Old   May 11, 2017, 07:13
Question simpleF, S-A, no convergence, sphere in air at re10^4
Anders Utnes
Alasir is on a distinguished road
Greetings. I'm a student attempting to simulate a few basic geometries and calculate their drag coefficients.
The specific case is a 3D grid of 1/4 of a sphere (0.1m diameter), floating in air (300K) thats going past with Re=10^4. I've used the 2D airfoil tutorial as a baseline. simpleFoam, Spalart Allmaras equations.
My problem is that after a relatively quick convergence at start, the residuals stops reducing. They fluctuate on the following scales:
U: 10^-5
P: 10^-3
NuTilde: 10^-5
And this is ultimately not enought to give me the expected Cd values.
Things I've tried in order to solve this, mostly from scanning different forum posts:
y+ verified to max 9.
Setting U, P, Nutilda tolerance to 1e-12, reltol to 0.05, 0.01, 0.05.
Setting simple's nNonOrthogonalCorrectors to 4.
Changed nut and nutilda freestream bds and internalstreams to be 1e-4, under the idea that 5*nu (1.57e^-5) would be better than the standard 0.14.
Changed grad(U) and grad(nuTilda) shemes to cellLimited leastSquares 1 from gauss linear.
Image of case:
http://imgur.com/a/oPcWJ
Boundary Conditions: (Note that Geo1 & Geo2 are the sphere's wall patches. Left and Bot are symmetryPlane patches.
nut:
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0.0001;
boundaryField
    Inlet
        type            freestream;
        freestreamValue uniform 0.0001;
    Outlet
        type            freestream;
    Top
        type            freestream;
    Right
        type            freestream;
    Left
        type            symmetryPlane;
    Bot
        type            symmetryPlane;
    Geo1
        type            nutUSpaldingWallFunction;
        value           uniform 0;
    Geo2
        value           uniform 0;
Nutilda:
boundaryField
    Inlet
        type            freestream;
    Outlet
        type            freestream;
    Top
        type            freestream;
    Right
        type            freestream;
    Left
        type            symmetryPlane;
    Bot
        type            symmetryPlane;
    Geo1
        type            fixedValue;
        value           uniform 0;
    Geo2
        type            fixedValue;
        value           uniform 0;
U:
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (1.57 0 0);
boundaryField
    Inlet
        type            freestream;
        freestreamValue uniform (1.57 0 0);
    Outlet
        type            freestream;
    Top
        type            freestream;
    Right
        type            freestream;
    Left
        type            symmetryPlane;
    Bot
        type            symmetryPlane;
    Geo1
        type            noSlip;
    Geo2
        type            noSlip;
P:
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    Inlet
        type            freestreamPressure;
    Outlet
    Top
    Right
    Left
        type            symmetryPlane;
    Bot
        type            symmetryPlane;
    Geo1
        type            zeroGradient;
    Geo2
        type            zeroGradient;
Transport properties:
transportModel  Newtonian;
rho             [1 -3 0 0 0 0 0] 1.18;
nu              [0 2 -1 0 0 0 0] 1.57e-05;
Turbulence Properties:
simulationType RAS;
RAS
    RASModel        SpalartAllmaras;
    turbulence      on;
    printCoeffs     on;
ControDict:
application     simpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         5000000;
deltaT          1;
writeControl    timeStep;
writeInterval   2000;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
functions
    forceCoeffs
        type        forceCoeffs;
        functionObjectLibs ( "libforces.so" );
        outputControl   timeStep;
        timeInterval    1;
        lRef        0.1;        //referanselengde
        log         yes;
        rho             rhoInf;      // Indicates incompressible
        rhoInf      1;       // Redundant for incompressible
        liftDir     (0 0 1);
        dragDir     (1 0 0);
        CofR        (0 0 0);  // Axle midpoint on ground
        pitchAxis   (0 1 0);
        magUInf     1.57;
        patches     ( Geo1 Geo2 );
        Aref        0.001964;        // referanseareal 0.00785
fvSheme:
ddtSchemes
    default         steadyState;
gradSchemes
    grad(U)         cellLimited leastSquares 1;
    grad(nuTilda)   cellLimited leastSquares 1;
    default         Gauss linear corrected;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind grad(U);
    div(phi,nuTilda) bounded Gauss linearUpwind grad(nuTilda);
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
fvSolution
solvers
    p
        solver          GAMG;
        tolerance       1e-12;
        relTol          0.01;
        smoother        GaussSeidel;
    U
        solver          smoothSolver;
        nSweeps         2;
        tolerance       1e-12;
        relTol          0.05;
    nuTilda
        nSweeps         3;
        tolerance       1e-12;
        relTol          0.05;
SIMPLE
    nNonOrthogonalCorrectors 4;
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-5;
        U               1e-5;
        nuTilda         1e-5;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        nuTilda         0.7;
Anyone got any ideas?
Alasir is offline   Reply With Quote
Old   May 18, 2017, 08:37
Anders Utnes
UPDATE:
I have found a small anamoly in the solution:
http://imgur.com/a/oUYJz
It appears that there is a problem with the mesh here.
I've tried to refine the mesh, but that just gave me 3 such anamolies other places. Anyone got any ideas?
I've used gmsh to generate the mesh:
RefinementLevel=200;
ge=0.05;
gw=ge/RefinementLevel;
l=1.5;
h=0.3;
d=0.05;
//inlet
Point(1)={0, 0, 0, 0.5*ge};
Point(2)={0, h, 0, 1.5*ge};
Point(3)={0, 0, h, 1.5*ge};
Point(4)={0, h, h, 2*ge};
//Outlet
Point(5)={l, 0, 0, ge};
Point(6)={l, h, 0, 1.5*ge};
Point(7)={l, 0, h, 1.5*ge};
Point(8)={l, h, h, 2*ge};
//Geometry
Point(10)={2*l/10, 0, 0, gw};
Point(11)={2*l/10+d, 0, 0, gw};
Point(12)={2*l/10+d, d, 0, gw};
Point(13)={2*l/10+d, 0, d, gw};
Point(14)={2*l/10+2*d, 0, 0, 2*gw};
//Main Lines
//Length
Line(20)={1, 10};
Line(21)={14, 5};
Line(22)={2, 6};
Line(23)={3, 7};
Line(24)={4, 8};
//inlet
Line(25)={1, 3};
Line(26)={3, 4};
Line(27)={4, 2};
Line(28)={2, 1};
//Outlet
Line(29)={5, 7};
Line(30)={7, 8};
Line(31)={8, 6};
Line(32)={6, 5};
//Geometry
Circle(40)={10, 11, 12};
Circle(41)={10, 11, 13};
Circle(42)={12, 11, 13};
Circle(43)={12, 11, 14};
Circle(44)={13, 11, 14};
//Loops
Line Loop(50)={25, 26, 27, 28};//inlet
Line Loop(51)={29, 30, 31, 32};//outlet
Line Loop(52)={25, 23, -29, -21, -44, -41, -20};//bot
Line Loop(53)={-27, 24, 31, -22};//top
Line Loop(54)={28, 20, 40, 43, 21, -32, -22};//left
Line Loop(55)={-26, 23, 30, -24};//right
Line Loop(56)={40, 42, -41};//Geometry 1
Line Loop(57)={42, 44, -43};//Geometry 2
//Planes
Plane Surface(60)={50};
Plane Surface(61)={51};
Plane Surface(62)={52};
Plane Surface(63)={53};
Plane Surface(64)={54};
Plane Surface(65)={55};
Ruled Surface(66)={56};
Ruled Surface(67)={57};
//Naming
Physical Surface("Inlet")={60};
Physical Surface("Outlet")={61};
Physical Surface("Bot")={62};
Physical Surface("Top")={63};
Physical Surface("Left")={64};
Physical Surface("Right")={65};
Physical Surface("Geo1")={66};
Physical Surface("Geo2")={67};
//Volume
Surface Loop(70)={60, 61, 62, 63, 64, 65, 66, 67};
Volume(71)={70};
Physical Volume("Internal")={71};
Old   May 18, 2017, 09:11
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Without analysing your case en détail:
simpleFoam is a steady state solver. You have a Reynolds number of 10,000. In this Re range we get a Kármán vortex street .
The iteration round in simple may be seen as pseudo time steps. In your case which is in reality transient it may be that the solver doesn't come to an end in your sense. You may select one or more monitoring point and look when the frequency of changing gets stable.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
simplefoam convergence, spalart allamras, sphere
UDF to calculate total air age in a air conditioned room rdrohit20 Fluent UDF and Scheme Programming 0 March 31, 2017 06:55
Natural Convection Air Temperature Problem theBerNii FLUENT 1 November 28, 2016 14:30
Air entrainment model setup for spillway oajor FLOW-3D 4 November 17, 2016 13:02
Is it possible to integrate air through a system with mixture of air and water? Hale OpenFOAM Post-Processing 1 September 30, 2013 09:57
Help - Two Phase Flow - Convergence Problem R.Sureshkumar Main CFD Forum 1 February 22, 2000 04:24
