unsteady flow problem
Old   May 10, 2017, 09:18
Default unsteady flow problem
ke Li
Hellodeutsch is on a distinguished road
Hello guys, im using an openfoam software to do my master project at the moment. And my simulation is about DNS on Internal combustion engine. So i need to make the inlet velocity time dependent.But in my result, the flow value like velocity in the flowfield except inlet place dont have obvious change. It looks like the change of value at other place cannot catch up the change of inlet velocity.If i made the inlet velocity invarient to do a steady simulation, the result is reasonable.
Could you please give me some possibilities on this problem?
Thanks in advance
Hellodeutsch is offline   Reply With Quote
Old   May 10, 2017, 09:54
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
Are you sure that you want (and are be a able) to solve such a complicated problem with DNS?
We cannot give an answer if we don't know, which solver you use, and how your boundary conditions are set.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   May 11, 2017, 07:07
ke Li
My solver is a self-made DNS simulation software made by our lab. Maybe it's hard to describe it detailly in such a short Message. But still thanks for your reply!
unsteady
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 19:30
problem regarding unsteady laminar flow adityanadig STAR-CCM+ 1 January 19, 2017 16:15
Problem with porous flow at multi-material interface with large permeability diff. Hisham OpenFOAM Programming & Development 1 June 3, 2016 11:51
Problem with changing mass flow rate roo FLUENT 3 June 4, 2013 15:53
Incompressible, Unsteady Cylinder Flow startingcfd Main CFD Forum 1 March 15, 2011 02:12
