PlaneWall2D Tutorial is broken and does not show proper T profile |
March 19, 2017, 07:35 |
Emre
Rep Power: 11 |
I try to run planeWall2D tutorial which is posted here: http://openfoamwiki.net/index.php/Ge..._-_planeWall2D But it does not show proper temperature profile as stated in the tutorial post: But mine is this: heat.jpg What is wrong with this tutorial? I use foam-extend-3.2 which does not contain this openFOAM tutorial but still ... |
May 23, 2018, 11:59 |
Emre
Rep Power: 11 |
It still seems broken. No temperature contour. paraFoam doesn't work.
May 24, 2018, 06:59 |
Robert
Rep Power: 12 |
Did your solver run at all? It doesn't look like it. So its not a paraview problem.
May 24, 2018, 19:16 |
Wouter van der Meer
Rep Power: 18 |
Hello ordinary,
In your paraview you are looking at time 0, if the problem has run, you need to forward the time to last (using the attached key on paraview). hope this helps Wouter |
May 25, 2018, 04:17 |
Robert
Rep Power: 12 |
Thats correct but will not help in this case as there are no further timesteps (see the zero behind the time counter).
May 25, 2018, 08:05 |
#6 | |
Rep Power: 14 |
Hello ordinary,
You are right, this tutorial does not work on some versions of OpenFOAM. For example to make it work on OpenFoam 4.1 you have to make changes in BCs as described in this post: planeWall2D tutorial: error running chtMultiRegionSimpleFoam You can try similar trick on your foam-extended but I dont guarantee it will work. Also for post processing make sure you follow these steps: Quote:
May 26, 2018, 10:11 |
#7 | ||
Emre
Rep Power: 11 |
Thank you for your attention RobertHB.
ordinary@toshiba:~/FOAM_RUN/planeWall2D$ openfoam50 ordinary@toshiba:~/FOAM_RUN/planeWall2D$ ./Allrun Running blockMesh on /home/ordinary/FOAM_RUN/planeWall2D Running topoSet on /home/ordinary/FOAM_RUN/planeWall2D Running splitMeshRegions on /home/ordinary/FOAM_RUN/planeWall2D Running chtMultiRegionSimpleFoam on /home/ordinary/FOAM_RUN/planeWall2D creating files for paraview post-processing Created 'planeWall2D.blockMesh' Created 'planeWall2D.OpenFOAM' Created 'planeWall2D{bottomAir}.OpenFOAM' Created 'planeWall2D{topAir}.OpenFOAM' Created 'planeWall2D{wall}.OpenFOAM' ordinary@toshiba:~/FOAM_RUN/planeWall2D$ paraFoam Quote:
temp.png temp2.png Thank you sweet_satan. I run this case in OpenFOAM 5.0. |
chtmultiregionsimplefoam, foam extend 3.2, heat tranfer |
