ERCOFTAC centrifugal pump case study with OpenFOAM extend 3.2
Old   March 8, 2017, 06:16
Default problem mixingPlane ERCOFTAC centrifugal pump case study with OpenFOAM extend 3.2
saleriCAE is on a distinguished road
Dear OpenFOAM extend community,
I would like to run the ERCOFTAC centrifugal pump case study with OpenFOAM extend 3.2.
I would like to use the solver MRFSimpleFOAM and the mixingPlane capability in order to mesh only a periodic part of the impeller.
My problem is connecting the impeller outlet mixingPlane with the diffuser inlet mixingPlane.
Looking at the tutorials, for example the axial turbine tutorial, the mixingPlane is applied connecting flat patches in the axial direction.
In my case this can be applied for connecting inlet pipe outlet with impeller inlet.
The flow enters the impeller in -Z direction and my boundary files looks like:
inletpipe_outlet
type mixingPlane;
nFaces 100;
startFace 11840;
shadowPatch impeller_inlet;
zone inletpipe_outletZone;
coordinateSystem
type cylindrical;
name mixingCS;
origin (0 0 0);
e1 (1 0 0);
e3 (0 0 1);
inDegrees true;
ribbonPatch
sweepAxis Theta;
stackAxis R;
discretisation bothPatches;
impeller_inlet
type mixingPlane;
nFaces 100;
startFace 12820;
shadowPatch inletpipe_outlet;
zone impeller_inletZone;
coordinateSystem
type cylindrical;
name mixingCS;
origin (0 0 0);
e1 (1 0 0);
e3 (0 0 1);
inDegrees true;
ribbonPatch
sweepAxis Theta;
stackAxis R;
But how should be written the boundary file for impeller outlet and vaned diffuser inlet since the interface is curved?
I have not found any tutorial nor material explaining that, can you please help me in setting up properly the boundary file for this application?
Thank you very much,
Remo
saleriCAE is offline   Reply With Quote
[DesignModeler] DesignModeler Scripting: How to get Full Command Access ANT ANSYS Meshing & Geometry 53 February 16, 2020 16:13
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Autoblade centrifugal pump template mahdi balali Fidelity CFD 3 February 18, 2014 09:56
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
