Ankit Dave
Rep Power: 10 ![]() |
I have meshes of impeller and stator, merged using mergeMeshes and I am using stitchMesh for creating an interface between impeller-outlet and stator-inlet.
And encountered following error, Duplicate point found in cut face. Error in the face cutting algorithm for global face 4(82015 107073 107072 82014) local face 4(87 88 85 84) Slave size: 858 Master size: 740 index: 56 Is there anything I have not considered? Please help me out. |
Kmeti Rao
Rep Power: 8 ![]() |
Hi Ankit,
I hope you did overcome this problem. It would be nice if you can share the end results, and the methods you followed. Right now I am stuck with the same problem Stitchmesh with SHM crashing. Thank you |
mergemeshes, openfoam, stitchmesh |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 11:37 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
