February 28, 2017, 16:42 |
Mixing tank SRFSimpleFoam problems
Namit Chaudhary
Hi everybody,
I am am new to OpenFoam and am working on simulating a mixing tank using SRFSimpleFoam. The agitator rotates at a speed of 200 rpm. The geometry is closed (surfaceCheck) and the the mesh is also OK (checkMesh).The maximum orthogonality is 59. The solver uses komegaSST model. I've tried multiple Urel boundary conditions. However, my omega continuously diverges. Can someone please help? smoothSolver: Solving for Urelx, Initial residual = 0.19671055, Final residual = 0.012671563, No Iterations 3 smoothSolver: Solving for Urely, Initial residual = 0.21467715, Final residual = 0.016775008, No Iterations 3 smoothSolver: Solving for Urelz, Initial residual = 0.34396204, Final residual = 0.020746431, No Iterations 3 DICPCG: Solving for p, Initial residual = 0.11815782, Final residual = 0.0011343767, No Iterations 27 time step continuity errors : sum local = 0.17293179, global = 2.2537818e-017, cumulative = -3.368218e-014 smoothSolver: Solving for omega, Initial residual = 0.0025648008, Final residual = 8.5676094e-005, No Iterations 2 bounding omega, min: -153.83346 max: 265415.18 average: 5884.1895 smoothSolver: Solving for k, Initial residual = 0.16180719, Final residual = 0.012939662, No Iterations 2 ExecutionTime = 374.456 s ClockTime = 374 s The p, Urel and omega values are below. 0/p Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } body { type zeroGradient; } dish { type zeroGradient; } agitator { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object Urel; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type SRFVelocity; inletValue uniform (0 0 0); relative no; value uniform (0 0 0); } body { type SRFVelocity; inletValue uniform (0 0 0); relative no; value uniform (0 0 0); } dish { type SRFVelocity; inletValue uniform (0 0 0); relative no; value uniform (0 0 0); } agitator { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object omega; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 -1 0 0 0 0]; internalField uniform 2.6; boundaryField { inlet { type omegaWallFunction; value $internalField; } body { type omegaWallFunction; value $internalField; } dish { type omegaWallFunction; value $internalField; } agitator { type omegaWallFunction; value $internalField; } } // ************************************************************************* // |
March 5, 2017, 09:31 |
Namit Chaudhary
I found something that works and gives a solution. I just changed the bc SRFVelocity to SRFWallvelocity. |
Sliding mesh setup for a mixing tank in Gambit | nycera | FLUENT | 13 | October 11, 2016 15:39 |
Tank Mixing Problem | davidleinster | CFD Freelancers | 6 | June 18, 2013 11:50 |
mesh of mixing tank in gambit | wemendibe | ANSYS Meshing & Geometry | 1 | June 3, 2013 02:32 |
Mixing Tank | jawidnaik | FLUENT | 11 | October 13, 2010 04:50 |
3D mixing tank using MRF/SRF | cfd_confuse | FLUENT | 0 | October 2, 2010 04:46 |
