Openfoam running error in parallel in Cluster
Old   February 19, 2017, 09:58
Smile Openfoam running error in parallel in Cluster
sibo
sibo is on a distinguished road
Hi All,
I was trying to run the airfoil flow field simulation in parallel using Cluster. I decompose the domain into 4 and run it using simpleFoam with 4 processors.
Then I get the following Errors:
COLOR="Red"]Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.[/COLOR]
But the exactly same case, can be run successfully in serial and even in parallel with 4 processors in my own laptop. But when i submit this job into Cluster, it said the error. And i also checked the decompose.log file, the domain was decomposed successfully. The above error is read from the case.log file.
Thanks in advance for your time!!
Any guide will be helpful.
sibo is offline   Reply With Quote
Old   February 19, 2017, 10:03
sibo
This is the entire case.log file:
Build : 2.1.x-ccbaf836072a
Exec : simpleFoam -parallel
Date : Feb 19 2017
Time : 21:27:00
Host : "compute-0-27.local"
PID : 62927
Case : /mnt/store1/home/sli218/2.18/angle-10NEW
nProcs : 4
Slaves :
3
"compute-0-27.local.62928"
"compute-0-27.local.62929"
"compute-0-27.local.62930"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Reading field p
Reading field U
with errorcode 1.
Old   February 25, 2017, 14:26
me3840 is on a distinguished road
You are looking at the stdout and it doesn't show the actual error. Your cluster should generate a stderr file with you should read, that will have the fault in it.
me3840 is offline   Reply With Quote
cluster, openfoam, parallel
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
openfoam pow() fails when running parallel Carlen OpenFOAM Programming & Development 9 February 23, 2015 03:02
Running Error using Compressible OpenFoam Parallel mode dhendria OpenFOAM Running, Solving & CFD 0 February 13, 2014 21:53
Running OpenFoam on a Computer Cluster in the Cloud - cloudnumbers.com Markus Schmidberger OpenFOAM Announcements from Other Sources 0 July 26, 2011 09:18
Running in Parallel on cluster NewFoamer OpenFOAM Running, Solving & CFD 3 November 3, 2010 17:20
