how merge dieselFoam & conjugateHeatFoam
Old   February 17, 2017, 10:17
Default how merge dieselFoam & conjugateHeatFoam
behnam
behnam71 is on a distinguished road
I want to merge dieselFoam & conjugateHeatFoam solvers in openFoam (1.6) to solve a spary combustion problem in a cylindrical combustion chamber with heat transfer in cylinder walls.
Can anyone help me?
How can i do this?
I saw MRFconjugateHeatFoam but did not help me.
behnam71 is offline   Reply With Quote
Old   February 21, 2017, 04:06
Nima Samkhaniani
nimasam is on a distinguished road
i recommend you to read the programmer guide to get familiar with OpenFOAM programming and try to read and understand some simple codes such as laplacianFoam, then try to combine these two solvers.
There is a book in Persian which can ease the process of OpenFOAM learning and programming for you (look here).
If you need some one to help you to write the code. send me a message.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
conjugateheatfoam, dieselfoam, openfoam 1.6-ext
[ICEM] ICE Mesh in ICEM - Block merge AA29 ANSYS Meshing & Geometry 19 March 23, 2018 07:08
merge two connectors v_herw Pointwise & Gridgen 1 August 28, 2014 10:14
[ICEM] Two boxes connected by a cylinder, blocks merge where I don't want them to merge. Polarbear ANSYS Meshing & Geometry 4 April 30, 2014 16:21
[ICEM] Merge mesh - non manifold vertices BrolY ANSYS Meshing & Geometry 4 October 30, 2010 23:07
about merge mesh lian Main CFD Forum 3 February 29, 2008 11:47
