command not found issue through an ssh server
Old   February 16, 2017, 23:10
Default command not found issue through an ssh server
Salim
Salim is on a distinguished road
I am new to open foam and ssh servers.
my problem is I need to run openFoam (simpleFoam simulation) through the university server which is an ssh server .
when I execute the (simpleFoam -help command) it gives me :
command not found
although the open foam 2.3.0 files are in the root of the uni server.
what could be the problem? is it a setup issue?
how can I fix that?
thanks in advance...
Salim is offline   Reply With Quote
Old   February 17, 2017, 02:35
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Did you source OpenFoam's bashrc file?
Or rather, since this is a cluster, did you load OpenFoam's module?
module avail
module <<INSERT OPENFOAM NAME FROM ABOVE OUTPUT HERE>>
floquation is offline   Reply With Quote
Old   February 17, 2017, 11:14
Salim
module avail
it does not work.
the OpenFoam 2.3.0 are already loaded in the cluster, as you see below in the image.
bear in mind that paraview software is working properly in the cluster.
Old   February 19, 2017, 18:08
Salim
when I try to excute ( simpleFoam) command through the terminal ,I got the following:
simpleFoam: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory
still waiting for your help guys !!!
Old   February 20, 2017, 03:17
floquation's Avatar
Kevin van As
All your figure shows is that OpenFoam is installed on the cluster. It does not show that OpenFoam is loaded.
Show us the output of these commands:
module avail
echo $FOAM_APPBIN
echo -e ${PATH//:/\\n}
which simpleFoam
Old   February 20, 2017, 03:50
Salim
module avail
echo $FOAM_APPBIN
which simpleFoam
these are the outputs
what could be the issue??
Old   February 20, 2017, 04:20
Antimony is on a distinguished road
Have you tried to source the bashrc file for OF using the command below?
source /opt/OpenFOAM/OpenFOAM-2.3.0/etc/bashrc
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   February 20, 2017, 04:38
Salim
Originally Posted by Antimony View Post
Cheers,
Antimony
yes
and it didn't work
Old   February 20, 2017, 07:26
floquation's Avatar
Kevin van As
Your output shows two things:
1) OpenFoam is indeed not loaded.
2) OpenFoam is not installed as a module on your cluster.
The latter is no problem, it just means that you have to source OpenFoam's bashrc file - which is exactly what Antimony just asked you to do.
Hence, the only thing we can help you with is with this question:
Originally Posted by Salim View Post
yes
and it didn't work
What exactly did you type? And what exactly happened when you did so?
"It didn't work" is so unspecific that we cannot help you.
Old   February 20, 2017, 15:28
Salim
Cheers,
Antimony
when I run simpleFoam
I got the same output in the terminal command:
I need to make the airfoil model run through the cluster
Old   October 28, 2019, 21:35
Default same problem with two nodes
  #11
Ndong-Mefane Stephane Boris
S_teph_2000 is on a distinguished road
I am trying to run the cavity example using two nodes (it works on both nodes in single node mode...), but I am having a problem similar to what is described above.
- When I run:
mpirun --hostfile machines -np 4 icoFoam -parallel
the application just hangs without any error message.
- When I try from node1:
ssh node2 "icoFoam -help"
I get the following error message
"bash: icoFoam: command not found"
Openfoam is installed on both nodes, the command "icoFoam -help" works when run on each node, and simple commands such as "ssh node2 'ls' " ran from node1 give the expected result.
I am using windows10 WSL
help please!!!
S_teph_2000 is offline   Reply With Quote
Old   November 20, 2022, 12:57
Matheus Montenegro Nunes
Matheus Nunes is on a distinguished road
But it worked for me, thank you!
Matheus Nunes is offline   Reply With Quote
Old   November 20, 2022, 12:58
Cheers,
Antimony
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
[Other] Compiling hacFoam (Ubuntu 10.04)(OF2.0.0)(LAMMPS13Jul2010)) Henrik_E OpenFOAM Installation 3 September 29, 2016 16:16
[General] Mac Os x system can't connect to X server when using ssh to access Linux system Ivy Zhou ParaView 2 September 30, 2013 10:21
injection problem Mark New FLUENT 0 August 4, 2013 01:30
