chemkinToFoam not working with therm.dat
Old   February 11, 2017, 15:13
Default chemkinToFoam not working with therm.dat
Carlos
SOFC is on a distinguished road
I have been trying to convert the therm.dat copied and pasted from http://detchem.com/ (more particularly reaction nš 7: Surface Reactions: Methane reforming kintetcs within a Ni-YSZ SOFC anode support), to the foam standard file by using chemkinToFoam. However, this does not seem to work. The following error appears:
--> FOAM FATAL ERROR:
while reading thermodynamic data specie phase on line 3
expected <char> (A1) but found '" " 0 300.00 5000.00 1000.00 1'
From function int Foam::chemkinReader::lex()
in file chemistryReaders/chemkinReader/chemkinLexer.L at line 1516.
Someone suggested in a previous (very old) thread to make use the dos2unix command, but this doesn't change anything.
Any idea on how to solve this issue?
Best regards.
SOFC
SOFC is offline   Reply With Quote
Old   April 17, 2019, 06:05
huangzhipeng
huangzp is on a distinguished road
hello,
do you have solve this problem. now, I want to achieve CH4 reforming in SOFC.
Looking for you help
huangzp is offline   Reply With Quote
Reaction Mechanism Issue (Therm.dat) MFGT CONVERGE 4 August 18, 2016 05:54
Is the subsetMotionSolver working in parallel? Arnoldinho OpenFOAM Running, Solving & CFD 7 April 27, 2016 05:38
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 03:01
Working directory mgonzalo FLUENT 1 November 11, 2011 11:05
viewing cfx post while working on cfx solver manager HMR CFX 5 March 9, 2011 23:33
