Non-newtonian/viscoelastic flow with heat transfer - which solver to use? |
February 8, 2017, 10:39 |
Rep Power: 10 |
I'm planning to simulate the flow of a nonlinear viscoleastic fluid with heat transfer as well as temperature dependent viscosity in OF Extend and I'm digging around to get all the information I need. To start, I'm running a few simulations with a shear thinning fluid using nonNewtonianIcoFoam, but it does not support heat transfer, is that right? I found a few links showing how to implement heat transfer in icoFoam, so I recon it is possible to do the same with nonNewtonianIcoFoam. Apparently, pisoFoam and pimpleFoam (or was it simpleFoam?) support non-newtonian behaviour as well. But as my work progresses, I will need to switch to viscoElasticFluidFoam and I'll need the temperature dependent viscosity, but I haven't found if it supports temperature-dependent viscosity or not. Is there a solver that fits my need out of the box or is it necessary to build my own? |
February 12, 2017, 05:34 |
A while (18 months?) ago I was asking myself the same question since I would maybe need to run a simulation of a nonNewtonian fluid with temperature dependent viscosity. I did not find a readily available model back than, but in the end the shear effects could be ignored for the project, so I did not investigate further. I did decide that it would have been necessary to develop a new viscosity model, so I guess that would still be my conclusion. Cheers, Tom |
February 12, 2017, 07:55 |
Rep Power: 10 |
it would be necessary to create a new solver combining viscoelastic fluid properties, heat transfer capabilities and temperature dependent viscosity. A member of the forum already did this, but unfortunately lost most parts of his data. So I guess I'll either adapt the models to the solvers or vice-versa, meaning combining existing solvers. |
December 25, 2017, 04:02 |
viscoelastic
farhad
Rep Power: 8 |
Hello
How can I form a vortex in a square-shaped channel? Or how can I see vortices? In all the papers, a vortex pair is seen at the corners of the channel with the Giesekus model. How can this be modeled with open foam? what is the properties flow ? B.C ? please help me? my Email: farhadhoseinbor@gmail.com Telegram id: @bfzah |
Solver for gas flow through porous media including heat transfer in OpenFOAM v3.0+ | Germilly | OpenFOAM Running, Solving & CFD | 30 | May 10, 2024 08:37 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 16:35 |
