simpleFoam with non uniform initial condition fails
Old   January 18, 2017, 12:07
Default simpleFoam with non uniform initial condition fails
Daniel
d.gavrila is on a distinguished road
I've a simpleFoam test case in which I replaced the U file with a non uniform initial condition filled from a calculation. The simpleFoam fails with the message :
--> FOAM FATAL ERROR:
cannot be called for a calculatedFvPatchField
on patch inlet of field U in file "/usr/local/pkg/src/OpenFOAM/rainbow-v1606+/run/tutorials/incompressible/simpleFoam/testCaseLIDAR/0/U"
You are probably trying to solve for a field with a default boundary condition.
From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientIntern alCoeffs() const [with Type = Foam::Vector<double>]
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187.
The whole test case ,inclusive the log.simpleFoam you can find at this URL
https://www.dropbox.com/s/1mnhzqvlxs...le.tar.gz?dl=0
The direct upload did not work because the U file is quite big, the size of list is 1.6e06
Many thanks,
Daniel
d.gavrila is offline   Reply With Quote
initial condition, non-uniform, simplefoam
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 22:33
should Courant number always be kept below 1? wc34071209 OpenFOAM Running, Solving & CFD 16 March 9, 2014 20:31
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
