how to add turbulence model in OpenFoam
Old   December 12, 2016, 19:18
Default how to add turbulence model in OpenFoam
Salim
Salim is on a distinguished road
Hi
I'm working on a Airfoil model in OpenFoam and it is required to Implement 4 new turbulence models.
I also trying to follow this tutorial (page 11 and 12)
http://www.tfd.chalmers.se/~hani/kur...ort_task_3.pdf
but I found it a little complicated as the commands style is a bit different and not easy to follow as I am new to the OpenFoam and terminal things.
could someone provide me an easy a step by step way to implement a new turbulence model???
many Thanks,
Salim
Salim is offline   Reply With Quote
Old   December 13, 2016, 21:25
Salim
any help????
Old   December 14, 2016, 18:24
Pete Bachant
pbachant is on a distinguished road
Which OpenFOAM version?
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
Old   January 30, 2017, 04:28
Salim
I use Openfoam 2.3 version currently
and this is my case files before running the simpleFoam:
http://www.tfd.chalmers.se/~hani/kur...bedi/files.tgz
Old   January 30, 2017, 20:51
Pete Bachant
Firstly, you really should spend a little time learning to use the terminal. I recommend going through the lesson at http://swcarpentry.github.io/shell-novice/
After that, the tutorial report you linked should work if you follow it step-by-step.
Old   January 30, 2017, 21:02
Salim
I have been working on the airfoil case
and I got this so far
I have been facing an issue which is when I try to run a simpleFoam to the my_airfoil_alpha1 file case it appears an error message saying that Unknown RASModel type mySpalartAllmaras..
I guess that I should add new turbulence model!!
but How ????
please help me I am stuck
Old   January 30, 2017, 21:14
Pete Bachant
You need to add your new turbulence models library to system/controlDict so OpenFOAM will know where to find the compiled code.
So, following the tutorial, you will need in controlDict:
libs ("libmyIncompressibleRASModels.so");
Old   January 30, 2017, 21:26
Salim
I already have done that...(you can check the link http://www.tfd.chalmers.se/~hani/kur...bedi/files.tgz)
but I got errors when I am trying to compile the turbulence models
after I execute the command ( wmake )
the error appears in the red colour for all 4 cases which are: mySpalartAllmaras ,
myZoneSpalartAllmaras,
myAlphaPdcSpalartAllmaras, myPdcSpalartAllmaras
and this appears at the bottom of the message after executing (wmake ) command in the terminal
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Which turbulence model is applicable for Plain diffuser flow simulation in openFOAM? mukut OpenFOAM Running, Solving & CFD 4 January 30, 2015 09:06
OpenFOAM: LES turbulence model names Ollie OpenFOAM 5 January 7, 2013 11:24
Add additional scalar to turbulence model john_w OpenFOAM 1 December 23, 2010 13:45
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 05:34
