December 8, 2016, 08:59 |
Error in If-else statement
fluidflowsteel
Rep Power: 10 |
Hi all, i have the following problem
VolscalarField X VolscalarField Y VolscalarField theta theta = atan(Y/X) We know that for theta = pi/2 or (3*pi)/2 etc. tangent values are undefined. Based on the X and Y coordinates of a point, I need to find out the angle theta in radians in OpenFOAM 3.0 I have written the following code which compiled without any errors forAll(X, cellI) { forAll(Y, cellI) { forAll(Theta, cellI) { if (X[cellI] == scalar(0.0)) { if (Y[cellI] > scalar(0.0)) { Theta = (Foam::constant::mathematical:i*0.5); } else { Theta = -(Foam::constant::mathematical:i*0.5); } } else if (X[cellI] > scalar(0.0)) { if (Y[cellI] > scalar(0.0)) { Theta = atan(Y/X); } else { Theta = (Foam::constant::mathematical:i*2) + atan(Y/X); } } else { Theta = (Foam::constant::mathematical:i) + atan(Y/X); } } } } It has compiled without any errors while running it is giving the following error. Seems to be related to something kind of 0/0 ? Can anyone help me ? Calculating scalar transport Courant Number mean: 0 max: 0 Time = 1e-12 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Thanks in advance With regards |
December 9, 2016, 07:23 |
khedar
Rep Power: 10 |
I would add a bunch of "Info" statements to pinpoint where "something/0" is occuring and then try to correct/modify it.
December 9, 2016, 07:46 |
fluidflowsteel
Rep Power: 10 |
Thanks for your input. Just found the function Foam::atan2(x,y) to calculate the angle theta (which can lie in any of the four quadrants) directly instead of if-else statements (the way i wrote the code in the thread). but in my case x and y are the volume scalar field. will it be like Theta = atan2f(x,y) ?
Help with if statement | CHARLES | OpenFOAM Programming & Development | 17 | August 22, 2021 04:14 |
compiling error to fortran statement DATA MASK_VELD/2#00000000000000001/ | JackG | Main CFD Forum | 0 | October 22, 2016 15:25 |
How to use if statement in openFoam solver? | rapierrz | OpenFOAM Programming & Development | 7 | August 4, 2015 06:19 |
Restricting area in if statement | Blackhawks84 | Fluent UDF and Scheme Programming | 4 | July 22, 2012 17:50 |
Weak statement for Galerkin Method | rugabug | Main CFD Forum | 0 | March 26, 2010 20:19 |
