Possible to select Cells next to a SPHERE surface? |
November 26, 2016, 13:12 |
David Long
Rep Power: 14 |
Hi Foamers,
Is it possible to use script over OpenFOAM to select specific cells to generate a new CellSet for use of mesh refinment? Since the topoSet tool does not have this type of source. As shown below, I want to refine the mesh around a sphere surface given the center O (x, y, z) and radius R. Note that inside this "sphere", cells do exist, i.e. the entire fluid domain is filled with uniform mesh via blockMesh. The reason why I want to do this, is because I want to test the Fictitous Domain Method (or Immersed boundary method) to calculate the drag over a solid 3D sphere. Inside this "sphere", U is treated as the velocity of solid sphere (Zero in this case) over time via rigid constrain. I know I can use snappyHexMesh to refine cells inside a sphere with a STL mesh file: Code:
limitRegions { sphere3D.stl // O (x, y, z), rad = R { mode inside; levels ((1e10 4)); } } Code:
... for (AllCells) { // D: distance between cell center to O (x, y, z) // H: thickness of refinement (e.g R/10) if ( | D - R | <= H) do Add Cell-ID to CellSet } best regards, David Last edited by keepfit; November 26, 2016 at 15:09. |
November 29, 2016, 08:56 |
Jan
Rep Power: 20 |
Hi David,
you should have a look at topoSet. E.g. you can create to cellSets with cell centres within a sphere with different radii. Then subtract one from the other. There are also other possibilities with topoSet, e.g. selection based on cell centres nearest to a list of coordinates or selection based on stl-surface. See a full list of possibilites in Code:
$FOAM_UTILITIES/mesh/manipulation/topoSet/topoSetDict Jan |
November 30, 2016, 16:47 |
#3 | |
David Long
Rep Power: 14 |
By the way, I thougght about to refine this specific region with a tedious but straight-forward method: i.e. create two closed mesh, which cover the cells between sphere-1 and sphere-2.Howvere, it seems that the "limitRegions" in sHM still does not work for both 3.0.x and 4.x. Maybe this feature is still not included? cheers, David |
refine mesh, sphere geometry |
[snappyHexMesh] SnappyHexMesh running killed! | Mark JIN | OpenFOAM Meshing & Mesh Conversion | 7 | June 14, 2022 02:37 |
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 10:26 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
In CFX workbench, which surface, i have to select | senCFX | CFX | 19 | December 19, 2011 02:31 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
